I found this routine which will select all similar mtexts and texts within a drawing at one time.
I am trying to figure out how to change it from selecting all objects within the drawing, to where the user would select a text, then it would highlight select all in the drawing.
Any help would be great.
(defun c:simtxt (/ lst Hltext text i)
  (if (setq lst    nil
            HlText (ssadd)
            text   (ssget "_x"
                          (list '(0 . "MTEXT,TEXT")
                                '(-4 . "<NOT")
                                '(1 . "")
                                '(-4 . "NOT>")
                                (cons 410 (Getvar 'ctab))
      (repeat (setq i (sslength text))
        (if (setq f (Assoc (setq str
                                  (cdr
                                    (Assoc 1
                                           (entget (setq e (ssname text (setq i (1- i)))))
                           Lst
          (progn (ssadd e HlText)
                 (if (not (ssmemb (cadr f) HlText))
                   (ssadd (cadr f) HlText)
          (setq lst (cons (list str (ssname text i)) lst))
      (sssetfirst nil HlText)
  (princ))
thank you.
Hi,
Be mindful is that the formatted Mtexts are not considered with this routine.
(defun c:Test (/ int sel ent str)
  ;; Tharwat - Date: 5.May.2021				;;
  ;; Select similar text contents based on selection.	;;
  (and (princ "\nSelect texts to select all similar text contents : ")
       (setq str ""
             int -1
             sel (ssget '((0 . "*TEXT")))
       (while (setq int (1+ int) ent (ssname sel int))
         (setq str (strcat str (cdr (assoc 1 (entget ent))) ","))
       (sssetfirst nil (ssget "_x" (list '(0 . "*TEXT") (cons 1 str) (cons 410 (getvar 'ctab)))))
Removing the "_X" will do the trick more here
  (if (setq lst    nil
            HlText (ssadd)
            text   (ssget (list '(0 . "*TEXT") ;this should do the same as '(0 . "MTEXT,TEXT")
                                '(-4 . "<NOT")
                                '(1 . "")
                                '(-4 . "NOT>")
                                  (cdr
                                    (Assoc 1
                           Lst
  (princ))
Edited by mhupp
Thank you Tharwat! Thats what i was trying to get it to do!
