VAC Posted May 6, 2021 Posted May 6, 2021 Hi, I have a simple dynamic block for elevation dimension - with field. It works OK for numbers below zero. It show "-" before. In drawings I have to use "+-" symbol (%%P) for +-0,000 elevation and "+" symbol for numbers above zero, +1,000 etc. Is there a way how to implement if statement for this?...if elev.<0 add nothing, if 0 add +-, if >0 add + before field. Example file attached. Many thanks dim.dwg Quote
