Plotting a monochrome raster?
I'm trying to plot a file with a raster image in it, however the raster has color and but I required the drawing to be monochrome. When I plot to PDF the raster stays color and the vector objects behave normally. Any ideas?
Thanks in Advance.
Check the settings of your PDF driver (Adobe?) directly from the Windows Control Panel under 'Printers and Faxes'. Make sure it's set to print on grayscale, if it's not, change it, restart AutoCAD and try again.
Thanks, knew it had to be an easy fix. I got fixated on the AutoCAD menus and didn't think to check the plotter's settings.
