land234 Posted February 9, 2009 Posted February 9, 2009 How can I do this? I convert through the export command (acad 14) and when I open the file in Illustrator none of the lines line up very well. some of the dimentions are not even legable. I just need to eventually take the cad drawing and have it put in InDesign... Is this even possible? or is the result the best I'm going to get? Thanks in advance!! Quote
dbroada Posted February 9, 2009 Posted February 9, 2009 I'm not sure pre R14 but for R14 we created eps files by printing to a postscript printer - installed by the add plotter command. By using a plotter you can specify line widths using the ctb file. Quote
