Philipp Posted May 22, 2021 Posted May 22, 2021 Hello! In trimble nova there is a command called draggen. It is used to catch an entity, copy it and when placed it can be rotated with tab 90° every tap on a key (space or tab I think). Also the entitys are self aligning on straight lines. I have here a concept of rotating a block 90°: ; (defun c:RT (/ cEnt) (setq cEnt (ssget)) (if (null cEnt) (setq cEnt (entget "\n Select Objects: ")) ) (command "ROTATE" cEnt "" "@0,0,0" 90) (while (or (initget "Y") (/= "N" (setq response (getkword "\nRotate again? (Y/ESC): ")) (command "ROTATE" "P" "" "@0,0,0" 90) ) ) ) ) ; The problem in this is that it will only rotate two times. Can it be written into a circeling program? Also I have a self aligning block, (I hope it works with autocad) The problem is, I will need to copy the block at first, it should not copy it, but search for the information and insert a new one with all parameters of the old to get the base point wich is aligning So the program should work like: -Chose Block in drawing -Insert exact same Block with aligning Basepoint on handle -(like rotate via key it would be nice to put in a list of offsets and scroll through) -click to place -the rotate 90° each tab on a key -Enter to confirm Does anyone know a lisp program that reassambles the "draggen" command or can someone help me to write the lisp? NONAME_0.dwg Quote
BIGAL Posted May 23, 2021 Posted May 23, 2021 This was answered previously and would just keep going, will try to find. I think Lee-mac may have provided a solution. The auto align could be added as a choice Quote
Philipp Posted May 29, 2021 Author Posted May 29, 2021 I found this thread but I dont think it is what you meant: copy-and-rotate-multiple Unfortunatly the posted code does not work anyways it say "invalid parameter" after defining new base-point Has someone found a solution to get the command done posted earlier? Quote
