chubbyowl Posted July 7, 2021 Posted July 7, 2021 I have a polyline (red, chainage) and I used measure to put block (perpendicular line) at every 5m of the line. I am looking for way to get the bearing of each of this block faster way. Right now I get each angle one by one. Can anyone please help me get the bearings/angle of each polyline perpendicular to the red line? I attached an image and dwg for your reference. Thanks so much Curve.dwg Quote
BIGAL Posted July 8, 2021 Posted July 8, 2021 If you look at any of the Chainage.lsp code that is out there, you will find a mention of vlax-curve-getfirstderiv here is an example defun for each point. (defun alg-ang (obj pnt) (angle '(0. 0. 0.) (vlax-curve-getfirstderiv obj (vlax-curve-getparamatpoint obj pnt ) ) ) ) Quote
