Steve221 Posted July 9, 2021 Share Posted July 9, 2021 (edited) I'm trying to batch print several paper space layouts in one PDF using MText/insert Field/SystemVariable/ctab. I want each unique tab name to print on each page Whatever page is active when I save is printed on all pages of the PDF. Doesn't matter if I put the MText on the model page or the layout tab. Is this possible without a script or coding? Using AutoCad LT -2022 Edited July 9, 2021 by Steve221 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted July 13, 2021 Share Posted July 13, 2021 (edited) Have you looked at "Publish" having LT makes it hard to program an answer. Publish from LT Edited July 13, 2021 by BIGAL Quote Link to comment Share on other sites More sharing options...
Steve221 Posted July 14, 2021 Author Share Posted July 14, 2021 Thanks, but same result. The ctab system variable is the same on each tab when printed or published. Quote Link to comment Share on other sites More sharing options...
Steve221 Posted July 14, 2021 Author Share Posted July 14, 2021 Found the answer... Needed to go to OPTIONS/USER PREFERENCES/FIELDS/FIELD UPDATE SETTINGS.../ and check PLOT Quote Link to comment Share on other sites More sharing options...
