ILoveMadoka Posted July 22, 2021 Posted July 22, 2021 This code works perfectly in what it does (if (setq A2 (ssget "_X" '((0 . "TEXT,MTEXT")))) (foreach ent (mapcar 'cadr (ssnamex A2)) (vla-put-layer (vlax-ename->vla-object ent) "TEXT") (vla-put-color (vlax-ename->vla-object ent) "256") (vla-put-lineweight (vlax-ename->vla-object ent) "-1") (vla-put-linetype (vlax-ename->vla-object ent) "ByLayer") ) ) I want to add a line to also change the text style. I thought it would be as simple as this (vla-put-stylename (vlax-ename->vla-object ent) "MyPredefinedTextStyle") but that does not work. I've tried a couple of these vla-put-activetextstyle vla-put-fontfile vla-put-stylename vla-put-textfont vla-put-textfontstyle vla-put-textstyle vla-put-textstylename (but not all) so I thought I'd ask. Am I close or way off base? Quote
mhupp Posted July 22, 2021 Posted July 22, 2021 (edited) that's it make sure its not on a locked/forzen layer. might not work if text is inside a block. (vla-put-stylename (vlax-ename->vla-object ent) "standard") also make sure you spelling the named style right. Edited July 22, 2021 by mhupp Quote
ILoveMadoka Posted July 23, 2021 Author Posted July 23, 2021 Gahhhhhh!! I had it correct but I had a typo in my style name! Thank you! Quote
