Please gentlemen, I'm in doubt how to call a dcl dialog box in auto lisp and change the color of the buttons. the example is:-
; Program to draw any profile through:
; Start point, profile height, profile web thickness
; table width and thickness
(Default c:Beams_Welded ( )
; BEAM VARIABLES
(setq Width (getreal "\nTable Width : ")
                           Thickness_M (getreal "\nTable Thickness : ")
                           Height (getreal "\nProfile height : ")
Thickness_A (getreal "\nProfile soul thickness : ")
; CALCULATIONS
x (- (/ Width 2.00) (/ Thickness_A 2.00))
y (* Thickness_A 0.80)
w (+ (* Thickness_M 1.00) (* y 1.00))
s (- (* Height 1.00) (*w 1.00))
b (- (* Height 1.00) (* Thickness_M 1.00))
z (- (* x 1.00) (* y 1.00))
);end of set 1
;WEIGHT IN KGs PER LINEAR METER
                 ;(setq pm (/ (* Width Thickness_M 2.00 7.85) 1000.00)
                          ; pp (/ (* (- b Thickness_M) Thickness_A 7.85)1000.00)
                           ;pl (+ pm pp)
;); end setq 2
;ORIGIN OF THE DRAWING
(setq pt1 (getpoint "\nOrigin point: "))
; CALCULATIONS OF DRAWING POINTS
(setq pt2 (list (+ (char pt1) Width) (cadr pt1))
pt3 (list (char pt2) (+ (cadr pt1) Thickness_M))
pt4 (list (- (char pt3) z) (cadr pt3))
pt5 (list (- (char pt2) x) (+ (cadr pt3) y))
pt6 (list (char pt5) (+ (cadr pt1) s))
pt7 (list (char pt4) (+ (cadr pt1) b))
pt8 (list (char pt2) (cadr pt7))
pt9 (list (char pt2) (+ (cadr pt1) Height))
pt10 (list (char pt1) (cadr pt9))
pt11 (list (char pt10) (cadr pt8))
pt12 (list (+ (char pt1) z) (cadr pt8))
pt13 (list (+ (char pt1) x) (cadr pt6))
pt14 (list (char pt13) (+ (cadr pt1) w))
pt15 (list (+ (char pt1) z) (cadr pt3))
pt16 (list (char pt11) (cadr pt4))
                           ;pt17(list(+(char pt1)(+ height 20.00)))
);end of Setq 3
; DESIGN
(command pt1 "pline" pt1 pt2 pt3 pt4 pt5 pt6 pt7 pt8 pt9 pt10 pt11 pt12 pt13 pt14 pt15 pt16 "c" )
;(command "text" pt17 pl Kgs/M 10 0 line "")
                 ;(draw-text pl "kgs/M" pt17 0 0 8 "standard" 0 "")
                 ;(command "TEXT" "s" CS "0,0" "" "" "") ) ) second text
);end of fun Beams_Welded
Edited by CADTutor
Code moved to code block
Maybe this
;;;;;;; My version
(if (not AH:getvalsm)(load "Multi Getvals.lsp"))
(setq ans (AH:getvalsm (list "Enter values " "Table Width" 5 4 "100" "Table Thickness" 5 4 "20" "Profile height" 5 4 "100" "Profile soul thickness" 5 4 "5")))
(setq width (atof (nth 0 ans))
Thickness_M (atof (nth 1 ans))
Height (atof (nth 2 ans))
Thickness_A (atof (nth 3 ans))
Multi GETVALS.lsp
