Elektrik Posted August 5, 2021 Posted August 5, 2021 Hi. Is there any lisp to to find convert all unexplodable blocks within a file to explodable blocks? You can set a block as explodable or unexplodable while creating a block or change this property later, but block by block. What I want is a lisp to convert all unexplodable blocks to explodable blocks. Thanks in advance. Quote
Steven P Posted August 5, 2021 Posted August 5, 2021 Google is your friend, I like google.... 1st result: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-make-unexplodable-blocks-explodable/td-p/2107647 2nd page and a LISP by RonJon (just stealing his thunder, no doubt he will be along later with the same link) 1 Quote
ronjonp Posted August 5, 2021 Posted August 5, 2021 Here's a quick one: (defun c:foo nil ;; RJP » 2021-08-05 (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (if (= 0 (vlax-get b 'islayout) (vlax-get b 'isxref)) (vlax-put b 'explodable -1) ) ) (princ) ) 2 Quote
Steven P Posted August 6, 2021 Posted August 6, 2021 On 8/5/2021 at 3:22 PM, ronjonp said: Here's a quick one: (defun c:foo nil ;; RJP » 2021-08-05 (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (if (= 0 (vlax-get b 'islayout) (vlax-get b 'isxref)) (vlax-put b 'explodable -1) ) ) (princ) ) I like your other way (from my link) better Quote
ronjonp Posted August 6, 2021 Posted August 6, 2021 11 minutes ago, Steven P said: I like your other way (from my link) better Why? This one does all block definitions. Quote
tombu Posted August 6, 2021 Posted August 6, 2021 (edited) On 8/5/2021 at 7:12 AM, Steven P said: Google is your friend, I like google.... 1st result: https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-make-unexplodable-blocks-explodable/td-p/2107647 2nd page and a LISP by RonJon (just stealing his thunder, no doubt he will be along later with the same link) ronjonp posted 3 different codes you should have linked to the one you liked and why to be clearer. Normally I'd always go with a coders recent post which he posted here yesterday but I did like the added option in his third post. It was on the second page. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-make-unexplodable-blocks-explodable/m-p/9314254#M395882 I use a lot of ronjonp's code on a daily basis like https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/publish-to-pdf-default-location/m-p/9831049#M406719 and snippets like (defun Trim0s (xb) ; Thank ronjonp (if (= (type xb) 'real); Trim 0's from end of string conversion, then trim . if it's at the end afterwards. (vl-string-right-trim "." (vl-string-right-trim "0" (vl-princ-to-string xb))) (itoa xb); if integer convert to string without trimming 0's from end. ) ) in code like: http://forums.augi.com/showthread.php?171064-Linetypes-and-Text-readability&p=1333199&viewfull=1#post1333199 that keeps my workflow running smooth. Thanks ronjonp! Edited August 6, 2021 by tombu Quote
ronjonp Posted August 6, 2021 Posted August 6, 2021 (edited) 46 minutes ago, tombu said: ronjonp posted 3 different codes you should have linked to the one you liked and why to be clearer. Normally I'd always go with a coders recent post which he posted here yesterday but I did like the added option in his third post. It was on the second page. https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-make-unexplodable-blocks-explodable/m-p/9314254#M395882 I use a lot of ronjonp's code on a daily basis like https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/publish-to-pdf-default-location/m-p/9831049#M406719 and snippets like (defun Trim0s (xb) ; Thank ronjonp (if (= (type xb) 'real); Trim 0's from end of string conversion, then trim . if it's at the end afterwards. (vl-string-right-trim "." (vl-string-right-trim "0" (vl-princ-to-string xb))) (itoa xb); if integer convert to string without trimming 0's from end. ) ) in code like: http://forums.augi.com/showthread.php?171064-Linetypes-and-Text-readability&p=1333199&viewfull=1#post1333199 that keeps my workflow running smooth. Thanks ronjonp! I do like that that snippet better Glad you can make use of the code I provide! That current path code with the reactor saves me sooooo much time browsing around our network. Edited August 6, 2021 by ronjonp 1 Quote
Steven P Posted August 6, 2021 Posted August 6, 2021 (edited) Yup, same one I was meaning, the one on the second page, 3rd post ("2nd page and a LISP by RonJon "... only saying.....) Edited August 6, 2021 by Steven P Quote
nolex Posted January 27 Posted January 27 On 8/6/2021 at 12:22 AM, ronjonp said: Here's a quick one: (defun c:foo nil ;; RJP » 2021-08-05 (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (if (= 0 (vlax-get b 'islayout) (vlax-get b 'isxref)) (vlax-put b 'explodable -1) ) ) (princ) ) This is very useful. Is there a version of this where I can only select some blocks and not all of them? Quote
ronjonp Posted January 27 Posted January 27 (edited) @nolex Give this quick modification a try: (defun c:foo (/ blx n nms s) ;; RJP » 2026-01-27 (cond ((setq s (ssget '((0 . "INSERT")))) (setq blx (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (foreach b (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (or (vl-position (setq n (vla-get-effectivename (vlax-ename->vla-object b))) nms) (vl-catch-all-apply 'vlax-put (list (vla-item blx n) 'explodable -1)) ) ) ) ) (princ) ) Edited January 29 by ronjonp 3 Quote
Nikon Posted January 29 Posted January 29 (edited) On 1/28/2026 at 2:52 AM, ronjonp said: (defun c:foo (/ n nms s) ;; RJP » 2026-01-27 (cond ((setq s (ssget '((0 . "INSERT")))) (foreach b (vl-remove-if 'listp (mapcar 'cadr (ssnamex s))) (or (vl-position (setq n (vla-get-effectivename (vlax-ename->vla-object b))) nms) (setq nms (cons n nms)) ) ) (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (and (vl-position (vla-get-name b) nms) (= 0 (vlax-get b 'islayout) (vlax-get b 'isxref)) (vlax-put b 'explodable -1) ) ) ) ) (princ) ) @ronjonp It's a great code! The program performs permission to explode for all blocks of the same name. Is it possible to perform permission to explode only for one (2, 3...) the selected block? Is it possible to leave the other blocks of the same name unchanged? Allow permission to explode for one of the block occurrences. Edited January 29 by Nikon Quote
ronjonp Posted January 29 Posted January 29 10 hours ago, Nikon said: @ronjonp It's a great code! The program performs permission to explode for all blocks of the same name. Is it possible to perform permission to explode only for one (2, 3...) the selected block? Is it possible to leave the other blocks of the same name unchanged? Allow permission to explode for one of the block occurrences. Hi Nikon. I'm not sure what you're asking? Quote
marko_ribar Posted January 29 Posted January 29 Ron, I think he thinks to make explodable only selected references and not definitions... Unfortunately, I think this is impossible... Quote
Nikon Posted January 29 Posted January 29 (edited) 30 minutes ago, ronjonp said: Hi Nikon. I'm not sure what you're asking? I apologize for my English. I use a translator, but I'm not sure if it translates well enough. I have several blocks with the same name. I want to allow exploding for only one selected block. Convert one unexplodable block to explodable block (another translation). Is it possible to leave the other blocks of the same name unchanged? Edited January 29 by Nikon Quote
BIGAL Posted January 29 Posted January 29 You may have to Wblock one block, open the wblock, change the explode to "Yes" then rename the block. You can now insert that block into your dwg say deleting the original block. But you will have 2 blocks. 1 Quote
ronjonp Posted January 29 Posted January 29 3 hours ago, Nikon said: I apologize for my English. I use a translator, but I'm not sure if it translates well enough. I have several blocks with the same name. I want to allow exploding for only one selected block. Convert one unexplodable block to explodable block (another translation). Is it possible to leave the other blocks of the same name unchanged? This is not possible that I'm aware of. The code above could be modified to explode the blocks selected then make those block definitions un-explodable again. 1 Quote
Lee Mac Posted January 29 Posted January 29 You could use this to rename the reference in question so that it references a different (duplicate) block definition, which could then be marked as explodable. 1 1 Quote
Nikon Posted January 30 Posted January 30 9 hours ago, Lee Mac said: You could use this to rename the reference in question so that it references a different (duplicate) block definition, which could then be marked as explodable. Yes, rename the block first, then use the @ronjonp code. Quote
