lisp to find convert all unexplodable blocks within a file to explodable blocks
Hi. Is there any lisp to  to find convert all unexplodable blocks within a file to explodable blocks? You can set a block as  explodable or unexplodable while creating a block or change this property later, but block by block. What I want is a lisp to convert all unexplodable blocks to explodable blocks.
Thanks in advance.
Here's a quick one:
(defun c:foo nil
  ;; RJP » 2021-08-05
  (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (if	(= 0 (vlax-get b 'islayout) (vlax-get b 'isxref))
      (vlax-put b 'explodable -1)
  • Like 2
On 8/5/2021 at 3:22 PM, ronjonp said:
Here's a quick one:
(defun c:foo nil
  ;; RJP » 2021-08-05
I like your other way (from my link) better
Why? This one does all block definitions.
On 8/5/2021 at 7:12 AM, Steven P said:
Google is your friend, I like google.... 1st result:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-make-unexplodable-blocks-explodable/td-p/2107647
2nd page and a LISP by RonJon (just stealing his thunder, no doubt he will be along later with the same link)
ronjonp posted 3 different codes you should have linked to the one you liked and why to be clearer.
Normally I'd always go with a coders recent post which he posted here yesterday but I did like the added option in his third post. It was on the second page.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-make-unexplodable-blocks-explodable/m-p/9314254#M395882
I use a lot of ronjonp's code on a daily basis like https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/publish-to-pdf-default-location/m-p/9831049#M406719
and snippets like
  (defun Trim0s (xb) ; Thank ronjonp
	(if (= (type xb) 'real); Trim 0's from end of string conversion, then trim . if it's at the end afterwards.
	  (vl-string-right-trim "." (vl-string-right-trim "0" (vl-princ-to-string xb)))
	  (itoa xb); if integer convert to string without trimming 0's from end.
in code like: http://forums.augi.com/showthread.php?171064-Linetypes-and-Text-readability&p=1333199&viewfull=1#post1333199
that keeps my workflow running smooth. Thanks ronjonp!
Edited by tombu
and snippets like
I do like that that snippet better :)
Glad you can make use of the code I provide! 🍻 That current path code with the reactor saves me sooooo much time browsing around our network.
Edited by ronjonp
  • Thanks 1
Yup, same one I was meaning, the one on the second page, 3rd post
("2nd page and a LISP by RonJon "... only saying.....)
Edited by Steven P
  • 4 years later...
On 8/6/2021 at 12:22 AM, ronjonp said:
Here's a quick one:
(defun c:foo nil
  ;; RJP » 2021-08-05
This is very useful. Is there a version of this where I can only select some blocks and not all of them?
@nolex Give this quick modification a try:
(defun c:foo (/ n nms s)
  ;; RJP » 2026-01-27
  (cond	((setq s (ssget '((0 . "INSERT"))))
	 (foreach b (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
	   (or (vl-position (setq n (vla-get-effectivename (vlax-ename->vla-object b))) nms)
	       (setq nms (cons n nms))
	   (and	(vl-position (vla-get-name b) nms)
