Guest Posted August 11, 2021 Posted August 11, 2021 (edited) Hi. I am using this code to find the closest distance between lines and polylines. With MDL code insert a line in the possition with the closest distance. Is it possible to change and insert an align dimension insted of a line ? ;; http://www.theswamp.org/index.php?topic=23170.60 ;; By Joe Burke, Charles Alan Butler and VovKa at theswamp. (defun MD:GetScreenCoords ( / ViwCen ViwDim ViwSiz VptMin VptMax) (setq ViwSiz (/ (getvar "VIEWSIZE") 2.0) ViwCen (getvar "VIEWCTR") ViwDim (list (* ViwSiz (apply '/ (getvar "SCREENSIZE"))) ViwSiz ) VptMin (mapcar '- ViwCen ViwDim) VptMax (mapcar '+ ViwCen ViwDim) ) (list VptMin VptMax) ) ;end ;; Arguments: ;; p1 - WCS or UCS point which defines the first corner of area ;; p2 - WCS or UCS point which defines the second corner of area ;; pt - point translated to UCS. ;; Returns: T if pt falls within area. (defun MD:PointInside (p1 p2 pt / xval yval) (and pt (setq pt (trans pt 0 1) xval (car pt) yval (cadr pt) ) (< (min (car p1) (car p2)) xval (max (car p1) (car p2))) (< (min (cadr p1) (cadr p2)) yval (max (cadr p1) (cadr p2))) ) ) ;end (defun c:MinDist ( / *error* doc blocks units obj1 obj2 typ1 typ2 pkpt p2 sc div fuzz d bd len inc idx resdist dellst res1 res2 pts locklst interflag z1 z2 diff temp reverseflag MD:Wait MD:NormalAngle MD:ParallelObjects MD:Pick MD:GetXrefs MD:UnlockLayers MD:RelockLayers MD:GetObject MD:XMark MD:UniformScale MD:XlineOrRay) ;; global vars: *mdp1* and *mdpt* (vl-load-com) (defun *error* (msg) (cond ((not msg)) ((wcmatch (strcase msg) "*QUIT*,*CANCEL*")) (T (princ (strcat "\nError: " msg))) ) (setvar "lunits" units) (if (and obj1 (not (vlax-erased-p obj1)) ) (vla-highlight obj1 acFalse) ) ;; Objects may be switched when a ray or xline ;; is involved. (if (and obj2 (not (vlax-erased-p obj2)) ) (vla-highlight obj2 acFalse) ) (MD:Wait 0.2) (redraw) (foreach x dellst (vla-delete x)) (MD:RelockLayers locklst) (vla-EndUndoMark doc) (princ) ) ;end error ;;; START SUB-FUNCTIONS ;;; ;; Unlock locked layers. ;; Argument: document object. ;; Returns a list of layer objects which were locked, ;; or nil if none are locked. ;; Typically the function filters out xref layers, ;; but not in this case. (defun MD:UnlockLayers (doc / laylst) (vlax-for x (vla-get-Layers doc) (if (eq :vlax-true (vla-get-lock x)) (progn (setq laylst (cons x laylst)) (vla-put-lock x :vlax-false) ) ) ) laylst ) ;end ;; Argument: a list of layer objects from UnlockLayers above. ;; Use vl-catch-all-apply in case a locked ;; layer was deleted in the calling function. (defun MD:RelockLayers (lst) (foreach x lst (vl-catch-all-apply 'vla-put-lock (list x :vlax-true)) ) ) ;end (defun MD:GetXrefs (blklst / lst) (if (vl-every '(lambda (x) (= (type x) 'ENAME)) blklst) (foreach blk (mapcar 'vlax-ename->vla-object blklst) (if (vlax-property-available-p blk 'Path) (setq lst (cons blk lst)) ) ) ) (reverse lst) ) ;end (defun MD:Wait (seconds / stop) (setq stop (+ (getvar "DATE") (/ seconds 86400.0))) (while (> stop (getvar "DATE")) (princ) ) ) ;end ;; Argument: angle in radians, any number including negative. ;; Returns: normalized angle in radians between zero and (* pi 2) (defun MD:NormalAngle (a) (if (numberp a) (angtof (angtos a 0 14) 0)) ) ;end ;; Returns T if two lines, rays or xlines are parallel. (defun MD:ParallelObjects (obj1 obj2 fuzz / ang1 ang2) (if (eq "AcDbLine" (vlax-get obj1 'ObjectName)) (setq ang1 (MD:NormalAngle (vlax-get obj1 'Angle))) (setq ang1 (MD:NormalAngle (angle (vlax-get obj1 'BasePoint) (vlax-get obj1 'SecondPoint))) ) ) (if (eq "AcDbLine" (vlax-get obj2 'ObjectName)) (setq ang2 (MD:NormalAngle (vlax-get obj2 'Angle))) (setq ang2 (MD:NormalAngle (angle (vlax-get obj2 'BasePoint) (vlax-get obj2 'SecondPoint))) ) ) (or (equal ang1 ang2 fuzz) (equal ang1 (MD:NormalAngle (+ pi ang2)) fuzz) (equal ang2 (MD:NormalAngle (+ pi ang1)) fuzz) (equal (MD:NormalAngle (+ pi ang1)) (MD:NormalAngle (+ pi ang2)) fuzz) ) ) ;end (defun MD:Pick (msg / typlst e obj typ scflag) (setq typlst '("AcDbLine" "AcDbArc" "AcDbCircle" "AcDbEllipse" "AcDbPolyline" "AcDb2dPolyline" "AcDb2dVertex" "AcDb3dPolyline" "AcDb3dPolylineVertex" "AcDbSpline" "AcDbRay" "AcDbXline" "AcDbPoint")) (setvar "errno" 0) (while (or (not (setq e (nentselp msg))) (not (setq obj (vlax-ename->vla-object (car e)))) (not (vl-position (setq typ (vlax-get obj 'ObjectName)) typlst)) (and (cadddr e) (not (apply 'and (mapcar 'MD:UniformScale (last e)))) (setq scflag T) ) ) (cond ((= 52 (getvar "errno")) (exit) ) ((not e) (princ "\nMissed pick. ") ) (scflag (princ "\nNon-uniformly scaled block detected, try again. ") (setq scflag nil) ) (typ (princ (strcat "\n " (substr typ 5) " selected, try again. ")) (setq typ nil) ) ) ) (if (or (eq "AcDb2dVertex" typ) (eq "AcDb3dPolylineVertex" typ) ) (setq obj (vlax-ename->vla-object (cdr (assoc 330 (entget (car e))))) typ (vlax-get obj 'ObjectName) ) ) ;; Used to mark xref. Point passed to MD:XMark. ;; The variable is local in the main routine. (setq pkpt (cadr e)) (if (= 2 (length e)) (list obj typ) (list obj typ (caddr e) (cadddr e)) ) ) ;end ;; Argument: UCS point. ;; Returns: nil (defun MD:XMark (pt / len p1 p2 p3 p4) (setq len (/ (getvar "viewsize") 75.0) p1 (polar pt (* pi 0.3) len) p2 (polar pt (* pi 0.7) len) p3 (polar pt (* pi 1.3) len) p4 (polar pt (* pi 1.7) len) ) (grdraw p1 p3 7) (grdraw p2 p4 7) ) ;end ;; Test for uniformly scaled block reference. (defun MD:UniformScale (obj / x y z) (if (= (type obj) 'ENAME) (setq obj (vlax-ename->vla-object obj)) ) ;; Added 7/2/2008. (if (wcmatch (vlax-get obj 'ObjectName) "*Dimension") T (progn (setq x (vlax-get obj 'XScaleFactor) y (vlax-get obj 'YScaleFactor) z (vlax-get obj 'ZScaleFactor) ) (and (equal (abs x) (abs y) 1e-12) (equal (abs y) (abs z) 1e-12) ) ) ) ) ;end ;; Argument: a list returned by MD:Pick. ;; Returns: a vla-object. The first object in list if the object is ;; not nested. Otherwise a transformed copy of the object. (defun MD:GetObject (lst / blkref blk obj) (cond ;; Object is not nested. ((= 2 (length lst)) (setq obj (car lst)) ) ;; Object is nested in an xref. Copy it within the xref database. ;; The owner is not specified within the CopyObjects function. ((setq blkref (car (MD:GetXrefs (last lst)))) (setq blk (vla-item blocks (vlax-get blkref 'Name))) (setq obj (car (vlax-invoke (vlax-get blk 'XRefDatabase) 'CopyObjects (list (car lst))))) (vla-transformby obj (vlax-tmatrix (caddr lst))) (setq dellst (cons obj dellst)) ;; Grdraw X mark on xref where it was selected ;; if it is the first object selected. (if (not obj1) (MD:XMark pkpt)) ) ;; Object is nested in a block reference. ;; Copy it from the block and highlight in the main ;; routine if it is the first object selected. (T (setq obj (car (vlax-invoke doc 'CopyObjects (list (car lst)) (vlax-get (vla-get-ActiveLayout doc) 'Block)))) (vla-transformby obj (vlax-tmatrix (caddr lst))) (setq dellst (cons obj dellst)) ) ) obj ) ;end ;; Argument: ray or xline vla-object. ;; Returns: a list of two 3D WCS points beyond where the object ;; intersects the edges of the current view. ;; The base point of a ray may be returned depending on its ;; location relative to the view. ;; Revised 6/30/2008. (defun MD:XlineOrRay (obj / basept zval secpt lst p pts p2 d typ expt1 expt2 MD:RectanglePts MD:RectangleList MD:FarthestPoint) ;;;; Sub-functions... ;; Pass two points representing a diagonal. ;; Returns a list of four UCS points. (defun MD:RectanglePts (p1 p2) (list p1 (list (car p2) (cadr p1) (caddr p1)) ; revised 6/27/2008 p2 (list (car p1) (cadr p2) (caddr p2)) ; should be OK within context, testing ) ) ;end (defun MD:RectangleList ( p1 p2 / rpts) (setq rpts (MD:RectanglePts p1 p2)) (mapcar '(lambda (a b) (list a b)) rpts (append (cdr rpts) (list (car rpts)))) ) ;end (defun MD:FarthestPoint (pt ptlst / x dist res) (setq x 0) (foreach p ptlst (setq dist (distance p pt)) (if (> dist x) (setq x dist res p) ) ) res ) ;end ;;;; End Sub-functions (setq basept (trans (vlax-get obj 'BasePoint) 0 1) zval (caddr basept) secpt (trans (vlax-get obj 'SecondPoint) 0 1) typ (vlax-get obj 'ObjectName) ) ;; two 2D UCS points (if (not sc) (setq sc (MD:GetScreenCoords)) ) (setq d (distance (car sc) (cadr sc)) sc (mapcar '(lambda (x) (append x (list zval))) sc) lst (MD:RectangleList (car sc) (cadr sc)) sc nil ) (foreach x lst (if (and (setq p (inters basept secpt (car x) (cadr x) nil)) (inters basept p (car x) (cadr x)) ) (setq pts (cons p pts)) ) ) (cond ((eq "AcDbXline" typ) (setq expt1 (polar (cadr pts) (angle (cadr pts) (car pts)) (* 2 d)) expt2 (polar (car pts) (angle (car pts) (cadr pts)) (* 2 d)) pts (reverse (list expt1 expt2)) ) ) ;; Revised 6/29/2008 ((eq "AcDbRay" typ) (setq expt1 (MD:FarthestPoint basept pts) expt1 (polar expt1 (angle basept secpt) (* 2 d)) pts (list basept expt1) ) ;; If base point is far away attempt to get a closer point ;; by testing for param at point. (setq expt2 (polar expt1 (angle secpt basept) (* 5 d))) (if (vlax-curve-getParamAtPoint obj (trans expt2 1 0)) (setq pts (reverse (list expt2 expt1))) ) ) ) ;; Trans UCS points to WCS as needed. (mapcar '(lambda (x) (trans x 1 0)) pts) ) ;end MD:XlineOrRay ;;; END SUB-FUNCTIONS ;;; ;;; START MAIN FUNCTION ;;; (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)) blocks (vla-get-Blocks doc) locklst (MD:UnlockLayers doc) units (getvar "lunits") ) (vla-StartUndoMark doc) (sssetfirst) (princ "\nSelect line, circle, arc, ellipse, polyline, spline, point, ray or xline.") (if (and (setq res1 (MD:Pick "\nFirst object: ")) (setq typ1 (cadr res1)) (princ (substr typ1 5)) (setq obj1 (MD:GetObject res1)) (not (vla-highlight obj1 acTrue)) ;; Get the screen coordinates here in case ;; the user pans between select objects. (if (or (eq "AcDbRay" typ1) (eq "AcDbXline" typ1) ) (setq sc (MD:GetScreenCoords)) T ) (setq res2 (MD:Pick "\nSecond object: ")) (setq typ2 (cadr res2)) (princ (substr typ2 5)) (setq obj2 (MD:GetObject res2)) ) (progn (cond ((equal obj1 obj2) (princ "\n Same object selected twice. ") (setq resdist 0.0 interflag T ) ) ((vlax-invoke obj1 'IntersectWith obj2 acExtendNone) (princ "\n Objects intersect. ") (setq resdist 0.0 interflag T ) ) ((and (eq typ1 "AcDbPoint") (eq typ2 "AcDbPoint") ) (setq *mdpt* (vlax-get obj1 'Coordinates) *mdp1* (vlax-get obj2 'Coordinates) d (distance *mdpt* *mdp1*) ) ) ((or (eq typ1 "AcDbPoint") (eq typ2 "AcDbPoint") ) (if (eq typ1 "AcDbPoint") (setq *mdpt* (vlax-get obj1 'Coordinates) *mdp1* (vlax-curve-getClosestPointTo obj2 *mdpt*) ) (setq *mdpt* (vlax-get obj2 'Coordinates) *mdp1* (vlax-curve-getClosestPointTo obj1 *mdpt*) ) ) (setq d (distance *mdpt* *mdp1*)) ) ;; Core stuff follows. (T (if (or (eq typ2 "AcDbRay") (eq typ2 "AcDbXline") ) ;; Reverse the objects and set a flag to reverse ;; the points later. (setq temp obj1 obj1 obj2 obj2 temp reverseflag T) ) (if (vlax-curve-getEndParam obj1) (setq len (vlax-curve-getDistAtParam obj1 (vlax-curve-getEndParam obj1))) ;; Obj1 is an xline or ray. (progn (setq pts (MD:XlineOrRay obj1) len (distance (car pts) (cadr pts)) idx1 (vlax-curve-getParamAtPoint obj1 (car pts)) idx2 (vlax-curve-getParamAtPoint obj1 (cadr pts)) ) (if (< idx1 idx2) (setq idx idx1) (setq idx idx2) ) ) ) (if (not idx) (setq idx 0)) ;; Number of divisions seems more than sufficient. (setq div 200 inc (/ len div) fuzz 1e-8 ) ;; Check first object for the closest point on second object. (setq bd (distance (setq *mdp1* (vlax-curve-getPointAtDist obj1 idx)) (vlax-curve-getClosestPointTo obj2 *mdp1*) ) ) (repeat (1+ div) (if (and (setq *mdp1* (vlax-curve-getPointAtDist obj1 idx)) (setq p2 (vlax-curve-getClosestPointTo obj2 *mdp1*)) ) (progn (setq d (distance *mdp1* p2)) (setq idx (+ idx inc)) (if (<= d bd) (setq bd d *mdpt* *mdp1*) ) ) ) ) ;; Refine the minimum distance as needed. Start with closest ;; point on first object. Bounce the closest points back and ;; forth between the two objects until delta distance is less ;; than the fuzz factor. (while (not (minusp (- (distance *mdpt* (setq *mdp1* (vlax-curve-GetClosestPointTo obj2 *mdpt*))) (setq d (distance *mdp1* (setq *mdpt* (vlax-curve-GetClosestPointTo obj1 *mdp1*)))) fuzz ) ) ) ) ) ) ;cond (if (and d *mdpt* *mdp1*) (progn (setq resdist d) ;; Added 9/6/2008. ;; If objects were reversed, reverse the points. (if reverseflag (setq temp *mdpt* *mdpt* *mdp1* *mdp1* temp) ) (grdraw (trans *mdpt* 0 1) (trans *mdp1* 0 1) -7 1) (if (and (or (eq "AcDbLine" typ1) (eq "AcDbXline" typ1) (eq "AcDbRay" typ1) ) (or (eq "AcDbLine" typ2) (eq "AcDbXline" typ2) (eq "AcDbRay" typ2) ) ) (if (MD:ParallelObjects obj1 obj2 1e-8) (if (and (eq "AcDbLine" typ1) (eq "AcDbLine" typ2)) (princ "\n Lines are parallel. ") (princ "\n Linear objects are parallel. ") ) ) ) ;; Check the Z values of the two closest points. (setq z1 (caddr *mdpt*) z2 (caddr *mdp1*) diff (abs (- z1 z2))) (cond ((equal z1 z2 1e-10)) ;; Units are scientific, decimal or engineering. ((< units 4) (princ (strcat "\n Z values of the points differ by: " (rtos diff units 10) ) ) ) ;; The maximum display accuracy of architectural or ;; fractional units is 0.00196. If diff is less, ;; change units to decimal. ((and (> units 3) (< diff 0.00196) ) (princ (strcat "\n Z values of the points differ by: " (rtos diff (setvar "lunits" 2) 10) ) ) (setvar "lunits" units) ) ;; Otherwise display diff in architectural or fractional units. (T (princ (strcat "\n Z values of the points differ by: " (rtos diff) ) ) ) ) ;cond ) ;progn ) ;if ) ;progn ) ;if (if (and resdist *mdpt* *mdp1*) (progn (princ (strcat "\n Distance: " (rtos resdist))) (if (not interflag) (progn (setq sc (MD:GetScreenCoords)) (if (or (MD:PointInside (car sc) (cadr sc) *mdpt*) (MD:PointInside (car sc) (cadr sc) *mdp1*) ) (princ " Enter MDL to place minimum distance line. ") (princ " Off screen points. MDL to place minimum distance line.") ) ) ) ) (princ "\n Could not calculate minimum distance. ") ) (*error* nil) (c:MDL) ) ;end MinDist ;shortcut (defun c:MD () (c:MinDist)) ;; Revised 6/30/2008. ;; Draw minimum distance line on the current layer. (defun c:MinDistLine ( / d sc ss) (cond ((not (and *mdpt* *mdp1*)) (princ "\n Minimum distance points not found. Run MD and then MDL to draw line.") ) ((and (setq d (distance *mdpt* *mdp1*)) ;(print d) ;testing (< d 1e-5) ) (princ "\n Minimum distance points are too close together. ") ) (T (entmake (list '(0 . "LINE") (cons 8 (getvar "clayer")) (cons 10 *mdpt*) (cons 11 *mdp1*) ) ) (setq sc (MD:GetScreenCoords)) (if (or (MD:PointInside (car sc) (cadr sc) *mdpt*) (MD:PointInside (car sc) (cadr sc) *mdp1*) ) (princ "\n Minimum distance line placed. ") (progn (princ "\n Minimum distance line placed off screen and selected. ") (sssetfirst nil (setq ss (ssget "L"))) ) ) ) ) (princ) ) ;end MinDistLine ;shortcut (defun c:MDL () (c:MinDistLine)) Thanks Edited August 11, 2021 by prodromosm Quote
mhupp Posted August 11, 2021 Posted August 11, 2021 (edited) its just a simple change the following (entmake (list '(0 . "LINE") (cons 8 (getvar "clayer")) (cons 10 *mdpt*) (cons 11 *mdp1*) ) ) to (vl-cmdf "dimaligned" "non" *mdpt* "non" *mdp1* "non" *mdpt*) Edited August 11, 2021 by mhupp added the *'s Quote
Guest Posted August 11, 2021 Posted August 11, 2021 Hi mhupp. I did this change but i can not see dimensions !!! (defun c:MinDistLine ( / d sc ss) (if (NOT (tblsearch "dimstyle" "_DIM")) (vl-exit-with-error (alert " Dimstyle _DIM does not exist !!!!")) ) ; end if (command "_layer" "_m" "DIM" "_c" "7" "" "_lw" "0.30" "" "") ;CREATE NEW LAYER (setvar "CLAYER" "DIM") (command "-DIMSTYLE" "R" "_DIM") (cond ((not (and *mdpt* *mdp1*)) (princ "\n Minimum distance points not found. Run MD and then MDL to draw line.") ) ((and (setq d (distance *mdpt* *mdp1*)) ;(print d) ;testing (< d 1e-5) ) (princ "\n Minimum distance points are too close together. ") ) (T (vl-cmdf "dimaligned" "non" mdpt "non" mdp1 "non" mdpt) (setq sc (MD:GetScreenCoords)) (if (or (MD:PointInside (car sc) (cadr sc) *mdpt*) (MD:PointInside (car sc) (cadr sc) *mdp1*) ) (princ "\n Minimum distance line placed. ") (progn (princ "\n Minimum distance line placed off screen and selected. ") (sssetfirst nil (setq ss (ssget "L"))) ) ) ) ) (princ) ) ;end MinDistLine ;shortcut (defun c:MDL () (c:MinDistLine)) Thanks Quote
mhupp Posted August 11, 2021 Posted August 11, 2021 16 minutes ago, prodromosm said: Hi mhupp. I did this change but i can not see dimensions !!! sorry didn't see the "*" (vl-cmdf "dimaligned" "non" *mdpt* "non" *mdp1* "non" *mdpt*) will do a dim rather then a line. you still need the other bit of the lisp as well Quote
