perecnicek Posted August 12, 2021 Posted August 12, 2021 Hi! I have a problem with my attribute. My attribute for door is defined by line lenght and this created backround for that attribute and i cant change the colour of it or deleted it. My others attribute are okay and work fine. Here is picture Thansk for help! Quote
CyberAngel Posted August 12, 2021 Posted August 12, 2021 My guess is that your door is a block and that you redefined the block at some point. What you may be seeing here is a block you inserted before you made the change. Use the ATTSYNC command, select the block, and all the instances will update (SYNChronize) to the new definition. Any attributes that got dragged or otherwise altered from the original definition will return to their default states, so you may need to check them. Quote
perecnicek Posted August 12, 2021 Author Posted August 12, 2021 5 minutes ago, CyberAngel said: My guess is that your door is a block and that you redefined the block at some point. What you may be seeing here is a block you inserted before you made the change. Use the ATTSYNC command, select the block, and all the instances will update (SYNChronize) to the new definition. Any attributes that got dragged or otherwise altered from the original definition will return to their default states, so you may need to check them. But this picture is not from model space but from testing block. Quote
perecnicek Posted August 12, 2021 Author Posted August 12, 2021 40 minutes ago, CyberAngel said: My guess is that your door is a block and that you redefined the block at some point. What you may be seeing here is a block you inserted before you made the change. Use the ATTSYNC command, select the block, and all the instances will update (SYNChronize) to the new definition. Any attributes that got dragged or otherwise altered from the original definition will return to their default states, so you may need to check them. But I did what you said and it didnt help. Quote
perecnicek Posted August 12, 2021 Author Posted August 12, 2021 I upload here my dwg for better understanding 2069659452_RDKRALIKOVA11.8.dwg Quote
BIGAL Posted August 13, 2021 Posted August 13, 2021 Use wblock next time and just select the door block no need for entire dwg. Sorry no answer to problem. Quote
