[C3D] Help needed with exporting / conversing Sample Lines.
Hello,
In Civil 3D I need to export Sample Lines with property "Sample Line Station Value" (SLSV), ideally to .shp.
Simplest (?) solution : LISP that would redraw sample lines with polylines or lines, adding values of SLSVs to polylines Hyperlink properties. Then during export I can converse it to anything i need.
That is because MAPEXPORT command doesn't allow me to export Sample Lines, also doesn't show SLSV property. Moreover, i can't find it within properties listed with ‘dumpallproperties’ of sample line, although ‘LIST’ command shows ‘station’ value.
Could You help me with such LISP or with finding some smart workaround ??
You may want to search also at say forums/autodesk they have a specific CIV3D section also, it has a couple of people very experienced in getting inside CIV3D database, often not straight forward.
And
Attached file example
To try it
