Request a variable and set a new variable with If function
Manuel_Kunde
Hi, I'm trying to query the variable "Weight" and if it has the content "50" I want to define a new variable: "Stamp" with the content "internal".
Is WCMATCH the right command for this?
(if (= wcmatch Weight "50") (progn (setq stamp "intern")))
Edited by Manuel_Kunde
Put a * either side of the 50 (for a wildcard search) and take out the = and it should work I think
(if (wcmatch Weight "*50*")
This works, thanks.
For an exact match, you can use:
(if (= weight "50") (setq stamp "intern"))
Note that the progn expression is not required as you are only supplying a single expression as the 'then' argument for the if statement.
