Hello :
someone knows what happens with my routine that does not explode the selection in window?
I want to exploit the blocks between a certain area and I can not
(defun c:pru (/)
(setq ss (ssget "_C" '(302681 -315028) '(309429 -317736.5) '((0 . "INSERT"))))
(command "_explode" ss "")
  );fin defun
pru.dwg pru.lsp
A couple of possible reasons:
  • Graphical selection methods require the objects to be visible within the drawing area in order to be selected.
  • The EXPLODE command will only operate on selection sets if QAFLAGS bit 1 is enabled.
Hence, the code might become something along the lines of:
(defun c:pru ( / pt1 pt2 qaf sel )
    (setq pt1 '(302681.0 -315028.0)
          pt2 '(309429.0 -317736.5)
    (command "_.zoom" "_w" "_non" pt1 "_non" pt2)
    (if (setq sel (ssget "_C" pt1 pt2 '((0 . "INSERT"))))
            (setq qaf (getvar 'qaflags))
            (setvar 'qaflags (logior 1 qaf))
            (command "_.explode" sel "")
            (setvar 'qaflags qaf)
    (command "_.zoom" "_p")
wow excellent master ...Thanks
10 hours ago, leonucadomi said:
Hello :
(defun c:pru (/)
  );fin defun
erased
Edited by devitg
wrong post
