This is a weird one. Trying to fig out how to make 8 view ports in model space. I would like the cvports to be # like this
2    6
3    7
4    8
5    9
Trying to do this so i can see tables in the drawing that are spaced apart with out having to pan/zoom around to each one.
Attached is an example drawing. as you can see the cvports are mixed up.
vports si to change it to a single viewport.
Drawing1.dxf
  • 2 weeks later...
This is what i have come up with. the only problem is the first zoom to object doesn't seem to be working. might be a BricsCAD error or something.
have to come back and zoom object again after the repeat is over for everything to work correctly.
(defun C:foo (/ i ss9 vlst c)
  (if (= tlst nil)
      (setq SS9 (ssget "_X" '((0 . "ACAD_TABLE") (8 . "TEXT") '(410 . "Model"))))
      (setq tlst (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS9))))
      (setq tlst (vl-sort tlst '(lambda (a b) (if (equal (car (cdr (assoc 10 (entget a)))) (car (cdr (assoc 10 (entget b)))) 1e-6)
                                          (> (cadr (cdr (assoc 10 (entget a)))) (cadr (cdr (assoc 10 (entget b)))))
                                          (< (car (cdr (assoc 10 (entget a)))) (car (cdr (assoc 10 (entget b)))))
  (if (= (length (vports)) 1)
      (vl-cmdf "_.vports" "4")
      (vl-cmdf "_.vports" "2" "H")
      (setvar 'cvport 3)
      (setvar 'cvport 4)
      (setvar 'cvport 5)
      (vl-cmdf "_.vports" "SI")
      (vl-cmdf "_.Zoom" "E")
      (setvar 'cvport 3)
      (setvar 'cvport 4)
      (setvar 'cvport 5)
  (setq vlst '(8 4 6 2 9 5 7 3)
        i 0
  (if (> (length tlst) 8)
    (setq c 8)
    (setq c (length tlst))
  (repeat c
    (setvar 'cvport (nth i vlst))
    (vl-cmdf "_.Zoom" "OB" (nth i tlst) "")
    (setq i (1+ i))
  (setvar 'cvport 8)
  (vl-cmdf "_.Zoom" "OB" (nth 0 tlst) "")
  (setq tlst (LM:RemoveItems '(0 1 2 3 4 5 6 7) tlst))
;;--------------------=={ Remove Items }==--------------------;;
;;  Removes the items at specified indexes from a list        ;;
;;  Author: Lee Mac, Copyright © 2011 - www.lee-mac.com       ;;
;;  Arguments:                                                ;;
;;  items - list of zero-based indexes to remove              ;;
;;  lst   - list from which items are to be removed           ;;
;;  Returns:  List with items removed                         ;;
(defun LM:RemoveItems (items lst / i)
  (setq i -1)
  (vl-remove-if '(lambda (x) (member (setq i (1+ i)) items)) lst)
