Copying and overwriting a Folder based upon date modified
I am trying to figure out how to copy and overwrite a folder based upon the last dated modified utilizing Lee's Copy Folder.
I look around and found this code, but not sure how to adapt it for a folder comparison.
https://www.cadtutor.net/forum/topic/70116-corona-virus-update-folders-server-to-home-help/
(vl-load-com)
(defun LM:copyfolder ( src des ovr / fso rtn )
    (if (setq fso (vlax-create-object "scripting.filesystemobject"))
            (setq rtn
                (not
                    (or (zerop (vlax-invoke fso 'folderexists src))
                        (vl-catch-all-error-p
                            (vl-catch-all-apply 'vlax-invoke
                                (list fso 'copyfolder src des (if ovr :vlax-true :vlax-false))
            (vlax-release-object fso)
            rtn
(defun c:comparefoldertest ( / FSO localfolder oldfolder)
      (setq localfolder (findfile "SPI_Ribbon.cuix") ;;Can it look at the folder date instead of file file?
            localfolder (vl-filename-directory localfolder)
            oldfolder (strcat localfolder "_alt"))
      (cond (*akttoday*
              (alert "Please restart AutoCAD and update again.")
              (exit))
            ((vl-file-directory-p oldfolder)
              (setq FSO (vlax-create-object "Scripting.FileSystemObject"))
              (vlax-invoke FSO "DeleteFolder" oldfolder :vlax-true)
              (vlax-release-object FSO))
      (cond ((and (not *akttoday*)(vl-file-directory-p localfolder))
              (setq *akttoday* 1)
              (vl-file-rename (strcat localfolder "\\") (strcat oldfolder "\\"))
              (LM:copyfolder "L:\\CAD\\AutoCAD\\AutoCAD_SPI_Ribbon" localfolder T)
              (alert "Ribbon updated sucessfully. Menu changes only available after restarting AutoCAD. "))
            (*akttoday*)
            (T (alert "Folder -->  \"AutoCAD_SPI_Ribbon\" \nWas not found!"))
  (prin1)
) ; end of defun
Hope this makes sense. Thanks for any ideas.
The world of google !!! Just had to know what to look for.
Download DOSLIB for Autocad or Bricscad
(dos_filedate "D:/acadtemp")
(("Acadtemp" . 20210902.17015))
Edited by BIGAL
