ACAD file does not modify the surface as polyline
Hi. When I convert a Civil 3D file to an ACAD file, the surface remains and the surface profile also. Not converted to poly lines. what to do?
You have to have the surface displayed via a style like contours and triangles then they will be exported also. Not sure about profiles always just did long sections etc.
It is like triangles. Nothing explode.
That is an export of a surface, you can do contours as well will end up with plines.
