I found some useful lisp in another forum in this topic: http://www.theswamp.org/index.php?topic=31097.0
but still I can't really figure out how to work with ZIP files.
What I need is to select one ZIP file, that has folders in which there are text files that I need to access. So all that just by selecting one ZIP file with getfiled. I could extract files first, but then I would have to combine them to use getfiled command.
I tried this code, written by someone in previously mentioned thread. It lists all files inside ZIP, all files in all folders. So I have file names, that are always a constant. Is there a way I could read from these certain files to get the data I want?
(defun C:TESTZIPCONTENTS (/ cont filz)
  (setq filz (getfiled "Select a ZIP File" "" "zip" 8))
  (setq cont (GetAllFilesInZip filz))
  (textscr)
  (princ (strcat "\nContents of \"" (vl-filename-base filz) (vl-filename-extension filz) "\":\n|"))
  (showint cont 0)
(defun moreinside (chkfile / cmt cnt fil its lst sbf)
  (if (= (vlax-get-property chkfile 'IsFolder) :vlax-true)
      (setq sbf (vlax-get-property chkfile 'getfolder))
      (setq its (vlax-invoke-method sbf 'items))
      (setq cmt (vlax-get-property its 'count))
      (setq cnt 0)
      (repeat cmt
	(setq fil (moreinside (vlax-invoke-method its 'item cnt)))
	(setq lst (cons fil lst))
	(setq cnt (1+ cnt))
      (vlax-release-object sbf)
      (vlax-release-object its)
      (gc)
      (cons (vla-get-name chkfile) (reverse lst))
(defun GetAllFilesInZip (zipFile / count file filelist files folder fso ndx path)
  (setq path (car (fnsplitl zipFile)))
  (setq fso (vlax-create-object "Shell.Application"))
  (setq folder (vlax-invoke fso 'NameSpace zipFile))
  (setq files (vlax-invoke folder 'Items))
  (setq count (vlax-get-property files 'Count))
  (setq ndx 0)
  (repeat count
    (setq file (moreinside (vlax-invoke files 'Item ndx)))
    (setq filelist (append filelist (list file)))
    (setq ndx (1+ ndx))
  (vlax-release-object folder)
  (vlax-release-object fso)
  (gc)
  filelist
(defun showint (a b / str)
  (setq str "\n|-")
  (repeat b (setq str (strcat str "-")))
  (foreach n a
    (if (listp n)
	(princ (strcat str ">" (car n)))
	(showint (cdr n) (1+ b))
      (princ (strcat str ">" n))
You have posted elsewhere and posted about unzipping from acad to a directory.
I can see in the GetAllFilesInZip function there is a call to the shell. I haven't ever worked with LISP in this mode but do so from C# apps all the time. Once you unzip the file and then search the files for particular text or patterns. Sorry I can't be much help beyond this point. Good luck with the task.
On 02/10/2021 at 09:13, BIGAL said:
Extract and read files from ZIP (theswamp.org)
Yes, and the same thing I'm asking here a little bit differently asked, but since then I managed to found out how to extract the files. I know the folder and files names. And now I want to know if there is a way to extract them to a temporary folder, or to delete them after I read extracted txt files. Basically by just selecting zip file to get wanted information, without having extracted files on my hard drive after using lisp
On 05/10/2021 at 15:52, mhupp said:
Thanks that is what I'm looking for, but its not working incorporated in my lisp, I also cannot delete the folder manually because it says the txt files inside that I'm reading from are in use. In autocad I get this: Automation Error. Description was not provided. Any way to make the files not being used anymore in lisp?
