ScoRm Posted October 1, 2021 Share Posted October 1, 2021 im using this lee mac's code to get the distance on every perpendicular line. and it works just fine. but I still have to move the text and put it in every perpendicular line. is there an easier way to do this? to catch up with the bunch of files i have to manually do? heres the code i copied ;;----------------------=={ Length at Midpoint }==----------------------;; ;; ;; ;; This program prompts the user for a selection of objects to be ;; ;; labelled and proceeds to generate an MText object located at ;; ;; the midpoint of each object displaying a Field Expression ;; ;; referencing the length of the object. ;; ;; ;; ;; The program is compatible for use with Arcs, Circles, Lines, ;; ;; LWPolylines, 2D & 3D Polylines, and under all UCS & View settings. ;; ;; ;; ;; The program will generate MText objects positioned directly over ;; ;; the midpoint of each object, and aligned with the object whilst ;; ;; preserving text readability. The MText will have a background mask ;; ;; enabled and will use the active Text Style and Text Height settings ;; ;; at the time of running the program. ;; ;;----------------------------------------------------------------------;; ;; Author: Lee Mac, Copyright Š 2013 - www.lee-mac.com ;; ;;----------------------------------------------------------------------;; ;; Version 1.0 - 2013-11-12 ;; ;; ;; ;; - First release. ;; ;;----------------------------------------------------------------------;; ;; Version 1.1 - 2016-01-16 ;; ;; ;; ;; - Modified LM:objectid function to account for 64-bit AutoCAD 2008. ;; ;;----------------------------------------------------------------------;; (defun c:midlen ( / *error* ent fmt idx ins ocs par sel spc txt typ uxa ) (setq fmt "%lu6") ;; Field Formatting (defun *error* ( msg ) (LM:endundo (LM:acdoc)) (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")) (princ (strcat "\nError: " msg)) ) (princ) ) (if (setq sel (ssget (list '(0 . "ARC,CIRCLE,LINE,*POLYLINE") '(-4 . "<NOT") '(-4 . "<AND") '(0 . "POLYLINE") '(-4 . "&") '(70 . 80) '(-4 . "AND>") '(-4 . "NOT>") (if (= 1 (getvar 'cvport)) (cons 410 (getvar 'ctab)) '(410 . "Model") ) ) ) ) (progn (setq spc (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace ) ) ) (setq ocs (trans '(0.0 0.0 1.0) 1 0 t) uxa (angle '(0.0 0.0) (trans (getvar 'ucsxdir) 0 ocs t)) ) (LM:startundo (LM:acdoc)) (repeat (setq idx (sslength sel)) (setq ent (ssname sel (setq idx (1- idx))) par (vlax-curve-getparamatdist ent (/ (vlax-curve-getdistatparam ent (vlax-curve-getendparam ent)) 2.0)) ins (vlax-curve-getpointatparam ent par) typ (cdr (assoc 0 (entget ent))) ) (setq txt (vlax-invoke spc 'addmtext ins 0.0 (strcat "%<\\AcObjProp Object(%<\\_ObjId " (LM:objectid (vlax-ename->vla-object ent)) ">%)." (cond ( (= "CIRCLE" typ) "Circumference") ( (= "ARC" typ) "ArcLength") ( "Length" ) ) " \\f \"" fmt "\">%" ) ) ) (vla-put-backgroundfill txt :vlax-true) (vla-put-attachmentpoint txt acattachmentpointmiddlecenter) (vla-put-insertionpoint txt (vlax-3D-point ins)) (vla-put-rotation txt (LM:readable (- (angle '(0.0 0.0 0.0) (trans (vlax-curve-getfirstderiv ent par) 0 ocs t)) uxa))) ) (LM:endundo (LM:acdoc)) ) ) (princ) ) ;; Readable - Lee Mac ;; Returns an angle corrected for text readability. (defun LM:readable ( a ) ( (lambda ( a ) (if (and (< (* pi 0.5) a) (<= a (* pi 1.5))) (LM:readable (+ a pi)) a ) ) (rem (+ a pi pi) (+ pi pi)) ) ) ;; ObjectID - Lee Mac ;; Returns a string containing the ObjectID of a supplied VLA-Object ;; Compatible with 32-bit & 64-bit systems (defun LM:objectid ( obj ) (eval (list 'defun 'LM:objectid '( obj ) (if (wcmatch (getenv "PROCESSOR_ARCHITECTURE") "*64*") (if (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring) (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false) '(LM:ename->objectid (vlax-vla-object->ename obj)) ) '(itoa (vla-get-objectid obj)) ) ) ) (LM:objectid obj) ) ;; Entity Name to ObjectID - Lee Mac ;; Returns the 32-bit or 64-bit ObjectID for a supplied entity name (defun LM:ename->objectid ( ent ) (LM:hex->decstr (setq ent (vl-string-right-trim ">" (vl-prin1-to-string ent)) ent (substr ent (+ (vl-string-position 58 ent) 3)) ) ) ) ;; Hex to Decimal String - Lee Mac ;; Returns the decimal representation of a supplied hexadecimal string (defun LM:hex->decstr ( hex / foo bar ) (defun foo ( lst rtn ) (if lst (foo (cdr lst) (bar (- (car lst) (if (< 57 (car lst)) 55 48)) rtn)) (apply 'strcat (mapcar 'itoa (reverse rtn))) ) ) (defun bar ( int lst ) (if lst (if (or (< 0 (setq int (+ (* 16 (car lst)) int))) (cdr lst)) (cons (rem int 10) (bar (/ int 10) (cdr lst))) ) (bar int '(0)) ) ) (foo (vl-string->list (strcase hex)) nil) ) ;; Start Undo - Lee Mac ;; Opens an Undo Group. (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc) ) ;; End Undo - Lee Mac ;; Closes an Undo Group. (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc) ) ) ;; Active Document - Lee Mac ;; Returns the VLA Active Document Object (defun LM:acdoc nil (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object)))) (LM:acdoc) ) (vl-load-com) (princ (strcat "\n:: MidLen.lsp | Version 1.1 | \\U+00A9 Lee Mac " (menucmd "m=$(edtime,0,yyyy)") " www.lee-mac.com ::" "\n:: Type \"midlen\" to Invoke ::" ) ) (princ) ;;----------------------------------------------------------------------;; ;; End of File ;; ;;----------------------------------------------------------------------;; sample.dwg Quote Link to comment Share on other sites More sharing options...
devitg Posted October 6, 2021 Share Posted October 6, 2021 Do you mean the length of each small line perpendicular to the large line , or the distance from the origin to each small line ? As I can see the value shown is the large line length. Please clear Quote Link to comment Share on other sites More sharing options...
ScoRm Posted October 14, 2021 Author Share Posted October 14, 2021 On 10/6/2021 at 11:42 PM, devitg said: Do you mean the length of each small line perpendicular to the large line , or the distance from the origin to each small line ? As I can see the value shown is the large line length. Please clear It's the latter sir, distance from the origin to each perpendicular line... I'm sorry it took me long time to reply. Quote Link to comment Share on other sites More sharing options...
devitg Posted October 14, 2021 Share Posted October 14, 2021 Hi ScoRm , find attached the lisp and the DWG result Please take care of not to have a duplicate long line , as on your posted dwg It ask to select the long line distance from start point.LSP get distance from origin to each perp line-no-text.dwg get distance from origin to each perp line-with-text.dwg Quote Link to comment Share on other sites More sharing options...
ScoRm Posted October 18, 2021 Author Share Posted October 18, 2021 On 10/15/2021 at 3:17 AM, devitg said: Hi ScoRm , find attached the lisp and the DWG result Please take care of not to have a duplicate long line , as on your posted dwg It ask to select the long line distance from start point.LSP 3.16 kB · 5 downloads get distance from origin to each perp line-no-text.dwg 50.87 kB · 5 downloads get distance from origin to each perp line-with-text.dwg 49.43 kB · 5 downloads this is it! thank you so much sir! this is a big help Quote Link to comment Share on other sites More sharing options...
