Is there any way to get the coordinates of the center point of the text I selected?
ekko
Set the text's justification to Mid Center
(defun C:Foo (/ ent pt)
  (setq ent (entsel "\nSelect Text To find Center Point: "))
  (setq pt (cdr (assoc 11 (entget (car ent))))) ;dxf code 11 is the insertion point of the text.
  ;(princ) ;no princ so you can see the point cords test by drawing a line and use cords shown.
@mhupp You have to check that the justification is not left otherwise code 11 is '(0 0 0).
(defun c:foo (/ ent pt)
  (if (setq ent (entsel "\nSelect Text To find Center Point: "))
    (setq pt (cdr (assoc (if (= 0 (cdr (assoc 73 (entget (car ent)))))
			   10
			   11
			 (entget (car ent))
  • Thanks 1
Calculate the bounding box of the text object, and then calculate the midpoint of the diagonal, e.g.:
(defun c:test ( / b e )
    (cond
        (   (not (setq e (car (nentsel)))))
        (   (not (setq b (LM:textbox (entget e))))
            (princ "\nInvalid object selected - please select text, mtext or attribute.")
        (   (entmake
                (list
                   '(000 . "POINT")
                    (cons  010 (trans (mapcar '(lambda ( a b ) (/ (+ a b) 2.0)) (car b) (caddr b)) e 0))
                    (assoc 210 (entget e))
        (   (princ "\nUnable to create central point."))
;; Text Box  -  Lee Mac (based on code by gile)
;; Returns the bounding box of a text, mtext, or attribute entity (in OCS)
(defun LM:textbox ( enx / bpt hgt jus lst ocs org rot wid )
    (cond
        (   (and (= "ATTRIB" (cdr (assoc 000 enx)))
                 (= "Embedded Object" (cdr (assoc 101 enx)))
            (LM:textbox (cons '(000 . "MTEXT") (member '(101 . "Embedded Object") enx)))
        (   (cond
                (   (wcmatch  (cdr (assoc 000 enx)) "ATTRIB,TEXT")
                    (setq bpt (cdr (assoc 010 enx))
                          rot (cdr (assoc 050 enx))
                          lst (textbox enx)
                          lst (list (car lst) (list (caadr lst) (cadar lst)) (cadr lst) (list (caar lst) (cadadr lst)))
                (   (= "MTEXT" (cdr (assoc 000 enx)))
                    (setq ocs  (cdr (assoc 210 enx))
                          bpt  (trans (cdr (assoc 010 enx)) 0 ocs)
                          rot  (angle '(0.0 0.0) (trans (cdr (assoc 011 enx)) 0 ocs))
                          wid  (cdr (assoc 042 enx))
                          hgt  (cdr (assoc 043 enx))
                          jus  (cdr (assoc 071 enx))
                          org  (list (cond ((member jus '(2 5 8)) (/ wid -2.0)) ((member jus '(3 6 9)) (- wid))      (0.0))
                                     (cond ((member jus '(1 2 3)) (- hgt))      ((member jus '(4 5 6)) (/ hgt -2.0)) (0.0))
                          lst  (list org (mapcar '+ org (list wid 0)) (mapcar '+ org (list wid hgt)) (mapcar '+ org (list 0 hgt)))
            (   (lambda ( m ) (mapcar '(lambda ( p ) (mapcar '+ (mxv m p) bpt)) lst))
                (list
                    (list (cos rot) (sin (- rot)) 0.0)
                    (list (sin rot) (cos rot)     0.0)
                   '(0.0 0.0 1.0)
;; Matrix x Vector  -  Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
    (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
(defun mxv ( m v )
Edited by Lee Mac
  • Agree 2
  • Thanks 1
-I wrote this last night but forgot to hit the post button, this is what I have done before.... but Lee Mac always has a nicer way to do things-
Probably a nicer way to do this, but tis is what I do
(defun c:gettextcentre ( / txtset Edata ptx_old pty_old pty_new ptx_new mycons)
  (setq txtset (ssget '((0 . "*TEXT")))) ;get text. Can use entget instead and also alter the line below
  (setq Edata (entget (ssname txtset 0)))
  (setq mycons 10)
  (if (/= 0 (nth 1 (cdr (assoc 11 Edata))))(setq mycons 11)) ;;if text alignment isn't left  use cons 11
  (setq ptx_old (nth 1 (assoc mycons Edata))) ;;current insertion point x
  (setq pty_old (nth 2 (assoc mycons Edata))) ;;and y
  (command "_.justifytext" txtset "" "MC") ;;set text alignment to Middle Centre
  (setq ptx_new (nth 1 (assoc mycons Edata))) ;; get centre coordinates
  (setq pty_new (nth 2 (assoc mycons Edata)))
  (if (< ptx_old ptx_new)(setq alignx "L"))
  (if (> ptx_old ptx_new)(setq alignx "R"))
  (if (= ptx_old ptx_new)(setq alignx "C"))
  (if (> pty_old pty_new)(setq aligny "T"))
  (if (< pty_old pty_new)(setq aligny "B"))
  (if (= pty_old pty_new)(setq aligny "M"))
  (setq xyalign (strcat aligny alignx))
  (command "_.justifytext" txtset "" xyalign) ;;reset text alignment to as before
(princ (assoc 11 Edata)) ;;return centre point as a list
  • Thanks 1
Lee's way is probably simplest but you can do something like this change the text to middle centre then retrieve the entget dxf 11 will show the centre so you would entmod 1st making it central then entget again. Will try to find some time to try it out.
Edited by BIGAL
32 minutes ago, BIGAL said:
Lee's way is probably simplest but you can do something like this change the text to middle centre then retrieve the entget dxf 11 will show the centre so you would entmod 1st making it central then entget again. Will try to find some time.
They normally are simplest, and usually work really well. My one I did a while ago and have learnt new stuff since then so there is probably a neater way to do that.
I looked at this this morning for a short while (busy week here....), i spotted a slight difference in the centre points between text middle centre justification and the centre of the text bounding box that Lee uses, probably won't make any difference though in all reality.
(my one is a part of another LISP to move the text to the centre of an object, a rectangle or circle or whatever and so having middle centre justification, then entmod dxf group 11 to a point, and then reset the justification to what it was works for me)
  • Thanks 1
Like this
(setq ent (car (entsel "\nPick text")))
(command "justifytext" ent "" "MC")
(setq pt (cdr (assoc 11 (entget ent))))
(command "undo" 1)
No Justifytext in Bricscad V20 ?
  • Thanks 1
4 hours ago, BIGAL said:
Like this
(command "undo" 1)
You have to have Express Tools installed.
  • Thanks 1
    (cond
        (   (entmake
                (list
                   '(000 . "POINT")
    (cond
        (   (cond
                          lst (textbox enx)
                (list
                   '(0.0 0.0 1.0)
(defun mxv ( m v )
(defun mxv ( m v )
thank you for your help, bro
5 hours ago, BIGAL said:
Like this
(command "undo" 1)
  (setq mycons 10)
			   10
			   11
			 (entget (car ent))
  • Thanks 1
