Regen Dynamic Block after changing its subentities color
Hello everyone
i used a lisp to change a dynamic block subentities color.but the changes will not reflect to the drawing unless i used the bedit command and save and close the block editor
here is screen shot showing the difference between the block in the model and the preview in Bedit command.
the Regen Command and (vla-Regen doc acAllViewports) methods doesn't work also to refresh the drawing to reflect changes to the block.
is there anyway to update/refresh the block to reflect changes made on it?
attached a drawing with a copy of the block.
thank you
regen problem.dwg
After you change the color maybe the function redraw could work.
(redraw entity 1)
-Edit-
Regen should work with blocks maybe it being a dynamic block. why its not updating.
(vla-regen (vla-get-activedocument (vlax-get-acad-object)) acactiveviewport)
Edited by mhupp
(redraw entity 1)
-Edit-
this didn't work for the block i attached.thank you anyway 😑
Edit: Worked after using the code posted in the forum you shared.thank you
Edited by handasa
