vanowm Posted October 23, 2021 Posted October 23, 2021 I'm looking for a script that would create a template (flat drawing) for a truncated cone, from 3 inputs: top/bottom diameter and height, like this: http://www.hampsonlife.com/conecalculator.php?dT=10&dB=40&h=25&form1=Calculate I've created a javascript that generates .dxf file, it works fine, but before I waste my time convert it into lisp, I was wondering if there is already such script available? My search didn't produce any results. Thank you. Quote
scj Posted October 23, 2021 Posted October 23, 2021 Have a look at www.ant-ares.de Good luck Jochen Quote
vanowm Posted October 23, 2021 Author Posted October 23, 2021 That is way overkill than just simply creating a polyline with 4 verities. Not to mention the price. Quote
mhupp Posted October 24, 2021 Posted October 24, 2021 (edited) Updated the lisp to create 1 closed polyline. (cond ((and (> r1 0) (> r2 0)) (setvar 'cmdecho 0) (command "_.pline" "_non" p1 "_A" "_S" "_non" p2 "_non" p3) (command "_L" "_non" p6 "_A" "_S" p5 "_non" P4 "_L" "_CL") (setvar 'cmdecho 1) ) (t (setvar 'cmdecho 0) (command "_.pline" "_non" p1 "_A" "_S" "_non" p2 "_non" p3) (command "_L" "_non" ip "_CL") (setvar 'cmdecho 1) ) ) Edited October 25, 2021 by mhupp Combin a line 1 Quote
