bustr Posted October 28, 2021 Posted October 28, 2021 (edited) When I click on a point a segment of line appears but I can not see the line between the last click point and my cursor. What useless system variable make plines visible or invisible as they are being drawn? Edited October 28, 2021 by bustr Quote
bustr Posted October 28, 2021 Author Posted October 28, 2021 I've done it with ortho on and off. The polyline shows up once I click the next point. It is not visible between the previous point and the cursor. Quote
bustr Posted October 28, 2021 Author Posted October 28, 2021 PLINEWID was the culprit. It was set to 1/32". When I zoomed in I could see it drag. Setting it to zero made it visible at zoom factor. Quote
eldon Posted October 28, 2021 Posted October 28, 2021 Perhaps if you post a drawing that you are having this problem with, someone can see if the problem can be reproduced and look at the system variables in case there is something screwy. Quote
