When editing text within AutoCAD LT 2010 when I click curser in middle of word to edit the spelling AutoCAD decides to select the whole word body prompting that I want to over wright the whole word? forcing me to use sideward arrow keys back and forth to get to where I want to insert text. How do I disable this and get text editing back to normal? Very annoying.
  • 1 month later...
Right-click the text instance and click Edit Text Instance. Select the text to modify. Use the Text Editor tab to change the text or apply different styles to the selected characters. Click outside the text instance to see your changes
  • 2 weeks later...
On 12/23/2021 at 10:55 PM, oliver07 said:
Right-click the text instance and click Edit Text Instance. Select the my lowes life text to modify. Use the Text Editor tab to change the pasco connect text or apply different styles to the selected characters. Click outside the text instance to see your changes
Hope this had helped you.
