Hi everybody
Can someone write me a lisp-code to export points to CSV?
1) User should select the entities
2) Enter Lisp Command
3) Windows explorer should appear, where to save the csv File with the points X-Y-Z
I would be very very happy for that! 1000 Thanks!
19 hours ago, Mepspec said:
Thank you, is there a solution without a GUI Menu?
Example
(defun c:testex ( / FILENAME FO LST NUM SS STR TLK X)
  (setq ss (ssget (list (cons 0 "point"))))
  (if (/= ss nil)
      (setq filename (getfiled "NAME THE EXPORT FILE" (strcat (getvar 'dwgprefix) (getvar 'dwgname)) "csv" 1))
      (setq fo (open filename "a"))
      (setq num 0)
	(setq tlk (ssname ss (setq x (- x 1))))
	(setq lst (cdr (ASSOC 10 (ENTGET tlk))))
	(setq str (strcat
		    (rtos (setq num (1+ num)) 2 0)
		    (rtos (nth 0 lst) 2 2)
		    (rtos  (nth 1 lst) 2 2)
		    (rtos  (nth 2 lst) 2 2)
		(write-line str fo)
      (close fo)
Edited by hosneyalaa
change
