Read CSV - String Values returning as symbols
Hi All - Long time viewer, first time poster. Excuse my inexperience with LISP - I'm currently trying to teach myself, but I'm hitting a stumbling block with the below example.
I have written a function to get a single cell value, based on the Column & row position of the value. This uses Lee Mac's ReadCSV program - I'm bringing the List of lists in, and locating the nth, nth value . this is all working fine, and I am able to use this functionality to write values to an Autocad table and some attributes/ text. the CSV file in question is a bill of materials export from Autodesk inventor, which contains a mixture of numbers & text.
(defun JS:CELLVALGET ( xval yval / data file cellval )
	(princ cell Value Ver 0.26")(princ)
	;FILE PATH OF CSV FILE EXPORT
	(setq file "XXXXX.csv")
	(setq data (LM:readcsv file))
	(setq cellval (nth (- xval 1) (nth (- yval 1) data)))
	(princ cellval)(princ)
The problem I am having is that if I want to do further manipulation, such as the simplified example below, I am running into an error.
(setq test (JS:CELLVALGET (2 1)))
(cond
((> (vl-string-search "APPLE" test 0) 1)
;DO STUFF
((> (vl-string-search "PLUM" test 0) 1)
;DO DIFFERENT STUFF
the data type for the variable "test" is a symbol and therefore vl-string-search fails with the error message:
Quote
error: bad argument type: symbolp  "APPLE"
I have tried the following functions with as part of the cellvalget subfunction with no joy: vl-symbol-value, vl-symbol-name, vl-princ-to-string but all return an empty value/error.
Any ideas? I suspect I am missing something obvious!
Why would it not be ((> (vl-string-search "APPLE" cellval 0) 1) ?
Another way
(setq cellval "APPLE")
"APPLE"
(wcmatch cellval "*APPLE*")
T
I do not know the function you use to read the CSV. But I suppose it expects string values to be formatted as such.
So a line in the CSV should look like this:
"abc",1,2.3,"def"
And not like this:
abc,1,2.3,def
No Roy  the csv ->lst accepts that they are strings. Any way this is what is required csv to table. It is hard coded for file needs to be changed, (setq fo (open "d:\\Acadtemp\\setout2.csv"  "R")) or change to getfiled.
; csv to list by lee-mac
(defun _csv->lst ( str / pos )
	(if (setq pos (vl-string-position 44 str))
		(cons (substr str 1 pos) (_csv->lst (substr str (+ pos 2))))
		(list str)
(defun AH:addlinet ( / rowcnt rowhgt)
(setq rowcnt (vla-get-rows objtable))
(setq rowhgt (vla-getRowHeight objtable 2))
(vla-InsertRows objTable rowcnt rowhgt 1)
(vla-settext objtable (- rowcnt 1) 0 (nth 0 lst))
(vla-settext objtable (- rowcnt 1) 1 (nth 1 lst))
(vla-settext objtable (- rowcnt 1) 2 (nth 2 lst))
(vla-settext objtable (- rowcnt 1) 3 (nth 3 lst))
(vla-settext objtable (- rowcnt 1) 4 (nth 4 lst))
(defun c:x2tab ( / )
(setq sp (vlax-3d-point (getpoint "pick a point for table")))
(Setq vgms (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setq numrows 3)
(setq numcolumns 5)
(setq rowheight 3.04)
(setq colwidth 60)
(setq objtable (vla-addtable vgms sp numrows numcolumns rowheight colwidth))
(vla-settext objtable 0 0 "SETOUT")
(vla-settext objtable 1 0 "NUMBER")
(vla-settext objtable 1 1 "EASTING")
(vla-settext objtable 1 2 "NORTHING")
(vla-settext objtable 1 3 "RL")
(vla-settext objtable 1 4 "DESCRIPTION")
(command "_zoom" "e")
(setq objtable (vlax-ename->vla-object (entlast)))
(while (setq nline (read-line fo))
(setq lst (_csv->lst nline))
(AH:addlinet)
(close fo)
;  (setq objtable (vlax-ename->vla-object (entlast)))
(SETQ Y 0 )
(repeat 5
(setq x 0)
(repeat (- (vla-get-rows objtable) 2)
(vla-setcelltextheight objtable (setq x  (+ x 1)) y 1.25)
(setq y (+ y 1))
(SETQ X 0)
(VLA-SETROWHEIGHT OBJTABLE (setq x  (+ x 1)) 3.04)
(setq x 0)
(repeat 5
(VLA-SetColumnWidth OBJTABLE x 25)
(setq x (+ x 1))
  • 3 weeks later...
All,
Cheers for the help - it turns out the princ statement in the subroutine was the culprit. After removing this, it ran nicely, and returned a value as a real number (as expected originally).
This could then be handled by the cond statements, triggering further subroutines.
I've now managed to complete the program - a task that previously took 3-4 hours, is now taking 10 minutes.
I love programming sometimes!
