rcb007 Posted November 15, 2021 Posted November 15, 2021 I am having a hard time trying to figure out how to stretch a side or (2 endpoints) of a viewport a few inches automatically. I can stretch objects within that area, but it will not allow me to select the viewport and slide that. (command "stretch" "19.05,-1.75" "24.5,25.0" "" "22.7,23.5719" "28.1011,23.5719") Thank you for the help. Quote
mhupp Posted November 15, 2021 Posted November 15, 2021 (edited) Are you in paper space? Is the layer the viewport is on unlocked? Your selection window has to in compass both endpoint grips to work on the viewport. Try it manually and see if it works. you might need to update your selection window. (command "stretch" pause pause "" "0,0" "5.4011,0") Edited November 15, 2021 by mhupp Quote
BIGAL Posted November 15, 2021 Posted November 15, 2021 Sort of easy using vl have 2 properties Width and Height so can stretch by the amount required, ok this will stretch left and right, ok so now there is a property Center so can do a move viewport based on center and new pt (setq obj (vlax-ename->vla-object (car (entsel "Pick obj")))) (vla-put-width obj 1000) (vla-put-center obj '(500 400)) Quote
rcb007 Posted November 16, 2021 Author Posted November 16, 2021 Thank you guys. BigAl, that is an interesting way of doing it. easy too. Quote
BIGAL Posted November 17, 2021 Posted November 17, 2021 Use dumpit.lsp and pick a viewport will expose all the variables that you can use to get the stretch to work. Hint Center. Quote
