Isolating blocks or objects with nested layers
Does anyone have a method to isolate blocks or objects, that have nested layers within the blocks?
I have blocks that have [for example (Layer A, Layer C, Layer 1, Layer 10)] contained in the block. The block resides on master layer (Layer Blocks).
I was hoping to isolate the (Layers Block) by selecting the object and it would also isolate the other layers with it.
Is that possible by any chance?
Hopefully if it can do that, it would be easily to unisolate it as well.
Try this:
(defun c:foo (/ e k l n)
  ;; RJP » 2021-11-22
  (layerstate-restore (setq k "RJP-NLAYISO") nil 2)
  (while (setq e (nentsel "\nSelect objects to isolate: "))
    (foreach x (append (list (car e)) (cadddr e))
      (or (vl-position (setq n (cdr (assoc 8 (entget x)))) l) (setq l (cons n l)))
  (if l
    (progn (setvar 'cmdecho 0)
	   (layerstate-save k 2 nil)
	   (command "_.layer" "_Freeze" "*" "")
	   (command "_.layer" "_Thaw" (apply 'strcat (mapcar '(lambda (x) (strcat x ",")) l)) "")
	   (setvar 'cmdecho 1)
Edited by ronjonp
Works Great Ronjon! Hate to ask this, anyway to "unfoo"? If not, I can still make this work. thank you again.
(defun c:unfoo nil (layerstate-restore "RJP-NLAYISO" nil 2))
