LISP FOR KEEP ORIGINAL LAYER WHEN USING COMMAND '' FLATSHOT''
Dear all,
In my model 3D solid have many layers. When I used the command '' FLATSHOT'' to make a 2D arrangement drawing. I want to make this command that all original layers will be kept. For example, in my model have 3 parts, each part will be one layer then I will FLATSHOT command. The 2D drawing will be layer similar vs layer in 3D model. Someone can help me a lisp to make it.
Thank all
Make a copy of what you want to flatten.
switch to the view you want to see the flatten object. (top, sides, ortho)
Use flatten and overkill command on copied object.
  • 8 months later...
command SECTIONPLANE
"T"  for type
"S" for slice
"O" for Orthographic
"T" for top
while livesection is on, select the sectionplane just created, a section tab should appear, there go up the slices until surpassing the highest point of your solids and in the slice widht put a number that can enclose all solids (for expla the highest cube in the example above is 100m tall, you put 150
now you have a slice the whole solid thick.
now click "generate section block"
in section settings, go to background lines:  show:yes
color: Bylayer
layer: go all the way up until *layerByObject*_backgroundlines   shows up and select it.
now "OK" and "Create"
