Organic Posted February 12, 2009 Share Posted February 12, 2009 Previously I could type "co" in command console, click an object and it would copy it. Now I must type co then select the object again. I.e. if I highlighted 10 and selected co it used to copy them, whereas now i have to reselect all 10 again. I used to also be able to select something, press the delete key and it would delete. This no longer works. How do I go back to what setting I had? Quote Link to comment Share on other sites More sharing options...
eldon Posted February 12, 2009 Share Posted February 12, 2009 Have you tried to set the system variable PICKFIRST to 1 Quote Link to comment Share on other sites More sharing options...
Organic Posted February 12, 2009 Author Share Posted February 12, 2009 Thanks, thats it. Quote Link to comment Share on other sites More sharing options...
