substitute block with another block, is this the best way to do it?
hello for update my P&ID i wrote  a lisp that check the filename and substitute a block "A" with a block "B", "C" with "D" etc etc
it's working fine but i'm not sure that is the best way to do it.
here an extract:
;;sostituisco linee con quelle straniere
;; Esempio sostituisco "A" con "CW"
  (if
    (and
    	(Setq lin_cw (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_cooling-water.dwg")) 	;;definisco blocco da inserire RIPETERE UN SETQ PER OGNI LINEA
		  (Setq lin_pw (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_potable-water.dwg"))
		  (Setq lin_hw (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_hot-water.dwg"))
		  (Setq lin_dw (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_demi-water.dwg"))
		  (Setq lin_chw (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_chilled-water.dwg"))
		  (Setq lin_fw (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_fire-water.dwg"))
		  (Setq lin_ww (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_well-water.dwg"))
		  (Setq lin_c (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_steam-condensate.dwg"))
		  (Setq lin_s (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_steam.dwg"))
		  (Setq lin_hs (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_high-pressure-steam.dwg"))
		  (Setq lin_pa (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_plant-air.dwg"))
		  (Setq lin_ia (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_instrument-air.dwg"))
		  (Setq lin_ba (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_breathing-air.dwg"))
		  (Setq lin_sa (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_atmospheric-air-in-suction.dwg"))
		  (Setq lin_aa (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_atmospheric-air.dwg"))
		  (Setq lin_p (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_process-fluid.dwg"))
		  (Setq lin_n (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_nitrogen.dwg"))
		  (Setq lin_ni(findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_nitrogen-low-purity.dwg"))
		  (Setq lin_ga (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_carbon-dioxide.dwg"))
		  (Setq lin_gi (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_inert-gas.dwg"))
		  (Setq lin_av (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_atmospheric-vent.dwg"))
		  (Setq lin_pv (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_vent-to-blow-down.dwg"))
		  (Setq lin_tv (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_vent-to-tox.dwg"))
		  (Setq lin_sv (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_safety-valve-vent.dwg"))
		  (Setq lin_vv (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_vacuum-vent.dwg"))
	  	(Setq lin_ns (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_brine.dwg"))
	  	(Setq lin_nh (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_ammonia.dwg"))
	  	(Setq lin_ps (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_process-sewer.dwg"))
	  	(Setq lin_uu (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_chemical-sewer.dwg"))
	  	(Setq lin_ss (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_meteoric-sewer.dwg"))
	  	(Setq lin_ff (findfile  "C:\\dati\\Lamberti_std\\block_update\\blocks\\lin_foam-fluid.dwg"))
		(	Vl-some '(lambda (nme)
			(if (wcmatch (strcase (getvar "DWGNAME"))
				     (strcat nme "*.DWG"))												              	;;se il file inizia con
			  nme
		     '("CH" "C1" "C2" "LI" "MN"	"ON" "NO" "RJ" "SH" "WT")							;;definisco iniziali nome file
	(progn																				                        	;;procedura sostituzione
	  (command "_-insert" lin_cw "-50,0" "" "" "" "" "" "" "" "" "")				;;inserisco blocco DEFINITO  NEL SETQ
	  (entdel (entlast))
		(if (setq ss (ssget "_X" '((2 . "lin_acquatorre"))))							  	;;blocco da sostituire
			(repeat (setq n (sslength ss))
			  (setq edata (entget (ssname ss (setq n (1- n)))))
			  (entmod (subst '(2 . "lin_cooling-water") '(2 . "lin_acquatorre") edata)) 	;;Prima blocco nuovo e poi quello da cambiare
	  (command "_-insert" lin_pw "-50,0" "" "" "" "" "" "" "" "" "")						;; inserisco blocco DEFINITO  NEL SETQ
	  (entdel (entlast))
		(if (setq ss (ssget "_X" '((2 . "lin_acquapotabile"))))								;blocco da sostituire
			  (entmod (subst '(2 . "lin_potable-water") '(2 . "lin_acquapotabile") edata)) 	;;Prima blocco nuovo e poi quello da cambiare
	  (command "_-insert" lin_hw "-50,0" "" "" "" "" "" "" "" "" "")						;; inserisco blocco DEFINITO  NEL SETQ
	  (entdel (entlast))
		(if (setq ss (ssget "_X" '((2 . "lin_acquacalda"))))								;blocco da sostituire
			  (entmod (subst '(2 . "lin_hot-water") '(2 . "lin_acquacalda") edata)) 	;;Prima blocco nuovo e poi quello da cambiare
	  (command "_-insert" lin_dw "-50,0" "" "" "" "" "" "" "" "" "")						;; inserisco blocco DEFINITO  NEL SETQ
	  (entdel (entlast))
		(if (setq ss (ssget "_X" '((2 . "lin_acquademi"))))								;blocco da sostituire
			  (entmod (subst '(2 . "lin_demi-water") '(2 . "lin_acquademi") edata)) 	;;Prima blocco nuovo e poi quello da cambiare
	  (command "_-insert" lin_chw "-50,0" "" "" "" "" "" "" "" "" "")						;; inserisco blocco DEFINITO  NEL SETQ
	  (entdel (entlast))
		(if (setq ss (ssget "_X" '((2 . "lin_acquagelida"))))								;blocco da sostituire
			  (entmod (subst '(2 . "lin_chilled-water") '(2 . "lin_acquagelida") edata)) 	;;Prima blocco nuovo e poi quello da cambiare
	   (command "_-insert" lin_fw "-50,0" "" "" "" "" "" "" "" "" "")						;; inserisco blocco DEFINITO  NEL SETQ
	   (entdel (entlast))
		(if (setq ss (ssget "_X" '((2 . "lin_acquantincendio"))))								;blocco da sostituire
			  (entmod (subst '(2 . "lin_fire-water") '(2 . "lin_acquantincendio") edata)) 	;;Prima blocco nuovo e poi quello da cambiare
is possible to write a list of original block and a list of new block an cycle the substitution?
thanks
