Casio47 Posted December 3, 2021 Share Posted December 3, 2021 Hello All, My Dimension Properties say my dimension is not associative. How do I change it to "yes" Thank you Quote Link to comment Share on other sites More sharing options...
tombu Posted December 3, 2021 Share Posted December 3, 2021 Take a look at the DIMASSOC (System Variable) https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-D77085A3-6E4C-4C18-AD70-21F54ED72492 Make sure it's set to 2 (default). As it's saved in the drawing this usually only happens when you get a drawing from someone else. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted December 6, 2021 Share Posted December 6, 2021 (edited) In case you want to restore association for one dimension, refer to this page. I did not know you could do that. In short, go to Annotate|Dimensions|Reassociate. Select the dimension and the object/points with which it should associate. Edited December 6, 2021 by CyberAngel 1 Quote Link to comment Share on other sites More sharing options...
