Hi .I am trying to write a code to change the text size in a drawing filter them by the textstyle
(defun C:test (/ scl a ts n th index b1 b c d b2)
(setq scl (getint "\n Give the scale  (50,100,200,250,500,etc) :")
     (setq a (ssget))
     (setq n (sslength a))
     (setq index 0)
     (repeat n
          (setq b1 (entget (ssname a index)))
          (setq index (+ index 1))
          (setq b (assoc 0 b1))
          (if (= "TEXT" (cdr b))
                    (setq c (assoc 40 b1))
		    (setq ts ht)
	            (setq d (cons (car c) ts))
                    (setq b2 (subst d c b1))
                    (entmod b2)
  (print)
The idea is to change the text size only in model space using as filter the text style
1) All the exist text in text style Area and Multy Area  ht = scl * 0.003
2) All the exist text in text style diast  ht = scl * 0.00175
3) All the other text   ht = scl * 0.0025
(command "-style" "Area" "arial.ttf" "0" "1.2" "0" "N" "N" "N")
(command "_.-style" "Multy Area" "arial.ttf" "0" "1" "0" "N" "N" "N")))
(setq ht(* 0.003 scl))
(command "-style" "diast" "wgsimpl.shx" "0" "1.2" "0" "N" "N" "N")
(setq ht(* 0.00175 scl))
(setq ht(* 0.0025 scl))
Thanks
Please note he doesn't want annotative text because problems when sending files to clients if i remember.
(defun C:test (/ scl ss txt style ht)
  (setq scl (abs (getint "\nSet Scale(50,100,200,250,500,etc): "))) ;abs to set number always positive
  (if (setq ss (ssget '((0 . "TEXT"))))  ;filter the selection here no need to test (if (= "TEXT" (cdr b))
    (foreach txt (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (setq txt (entget txt))
      (setq style (strcase (cdr (assoc 7 txt))))
      (cond
        ((or (eq "AREA" style)(eq "MULTY AREA" style)(eq "DIAST" style))
          (if (eq "DIAST" style)
            (setq ht (cons 40 (* 0.00175 scl)))
            (setq ht (cons 40 (* 0.003 scl)))
          (entmod (subst ht (assoc 40 txt) txt))
        (t ;everything else
          (setq ht (cons 40 (* 0.0025 scl)))
    (prompt "\nNothing Selected")
Edited by mhupp
