rcb007 Posted December 17, 2021 Posted December 17, 2021 I am looking for a method to walk a user through some steps within Autocad. I was hoping to have a modeless window that tells the user step by step process, but from Step 1 to Step 2 there would be a "OK" Button or similar to continue. I think that would give the user time to do the instructions then go onto the next step and so forth. I usually like using the acet-ui-status commands, but I cannot get it work with the above scenario. I also and looking at the dos_traywnd but it seems that it pops up for a few seconds before disappearing. Or maybe there is another way to do this. Thank you again for your help! Quote
mhupp Posted December 17, 2021 Posted December 17, 2021 Syntax (dos_traywnd title text width height [operation [duration]]) in milliseconds Alert pops up a message box in the middle of the screen and waits for the user to click ok before continuing with the lisp. (defun C:test () (alert "\nHow to draw a line") (alert "\nFirst you need to start the command \n Either by typing "line" or clicking the line icon") (alert "\nAfter the command is running you will be prompted to pick a starting point") (vl-cmdf "_.Line" pause) (alert "\nNow pick an end point") ) Quote
