mahmoud saleh Posted December 29, 2021 Posted December 29, 2021 I NEED TO MAKE THEM 3 POLYLINES NOT ONE Quote
mhupp Posted December 29, 2021 Posted December 29, 2021 (edited) Use the trim command with fence option. then use the pedit join Edited December 29, 2021 by mhupp Quote
mahmoud saleh Posted December 29, 2021 Author Posted December 29, 2021 4 minutes ago, mhupp said: Use the trim command with fence option. then use the pedit join NO I WANT TO MAKE THEM LIKE THIS BUT OVER EACHOTHER ANT MAKE THEM FILLETS TOO Quote
BIGAL Posted December 29, 2021 Posted December 29, 2021 If I understand correct this has been asked before the answer may be over at forums/autodesk you end up with 3 plines all connected back to the same start point. Think electrical wire. Sorry no idea what to google for. 1 Quote
mhupp Posted December 29, 2021 Posted December 29, 2021 15 minutes ago, mahmoud saleh said: NO I WANT TO MAKE THEM LIKE THIS BUT OVER EACHOTHER ANT MAKE THEM FILLETS TOO ah I see i think @ronjonp made something like that it was for pipe line or something. Quote
exceed Posted December 31, 2021 Posted December 31, 2021 (edited) take a look this wireruns.lsp need theswamp id http://www.theswamp.org/index.php?topic=45092.msg503931#msg503931 ====================================== if you have coordinates of destinations 1. spread destinations by texts to cad by excel or manually 2. then draw some main line (main tray) 3. and draw minimum shortest line between text and main lines, by lisp (by ronjonp) (defun c:MIN (/ _dxf _sl a b c e p s x) ;; RJP ≫ 2019-01-10 (defun _sl (s) (cond ((= 'pickset (type s)) (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))))) (defun _dxf (c e) (cdr (assoc c (entget e)))) (cond ((setq s (_sl (ssget))) (foreach x s (if (wcmatch (_dxf 0 x) "TEXT") ;edited line (setq b (cons (_dxf 10 x) b)) (and (= 'real (type (vl-catch-all-apply 'vlax-curve-getendparam (list x)))) (setq a (cons x a)) ) ) ) (and a b (foreach p b (setq c (car (vl-sort (mapcar '(lambda (x) (list (setq c (vlax-curve-getclosestpointto x p)) (distance p c) (_dxf 8 x)) ) a ) '(lambda (r j) (< (cadr r) (cadr j))) ) ) ) (setq e (entmakex (list '(0 . "LINE") (cons 10 p) (cons 11 (car c)) (cons 8 (caddr c))))) ;; This line below creates the right example comment out to get left ;; (setq a (cons e a)) ) ) ) ) (princ) ) 4. use mpedit command to make polyline 5. breaking all crossing polylines https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/break-all-polylines/m-p/2251689/highlight/true#M260485 add ucs w, ucs p line if you use this in custom ucs drawing 6. use wireruns lisp then I edit this "to points" inserts(block) -> text and If it is an alternative CAD other than AutoCAD, some modifications are required. 7. use fmp lisp (filletmultiplepolylines.lsp) https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/fillet-multiple-polyline-all-at-once-by-lisp/m-p/10151411/highlight/true#M412320 Edited December 31, 2021 by exceed 1 Quote
