Change path mode in "external references"
Hello friends
How can I
Change a photo "Change path mode"  from (make relative) to (make absolute) in "external references" toolbar
by autolisp in autocad 2021
Read and try this lisp file.
Change the path type of all xrefs to full.
To change only one external reference, replace the character "*" with "external reference name".
changetypepath.lsp
Edited by elyosua
(command "._-xref" "PathType" "*" "Full")
Although why would you want to do this? Relative paths are much more flexible ( ie what if you change your drive from E to F )
Thank you very much for your help
Because when (make relative) is active, and I use the command (vla-get-imagefile img), the answer is not complete
Maybe this?
(if (setq p (findfile (vla-get-imagefile vla-object)))
  (vla-put-imagefile vla-object p)
Edited by ronjonp
30 minutes ago, ronjonp said:
Maybe this?
Yes, that's exactly it
I did not see this problem in AutoCAD 2012 to 2018
Unfortunately, AutoCAD 2021 performs poorly on these commands
