With the following command you can select a line in attached drawing and retrieve data(using attached DWG):
(dictsearch
  (handent (cdr (assoc 5 (entget (cdr (assoc 360 (entget (car (entsel)))))))))
  "ESRI_Attributes"
With this we receive the following data(on some line):
((-1 . <Entity name: 1e75859a920>)
  (0 . "DICTIONARY")
  (5 . "83C2")
  (102 . "{ACAD_REACTORS")
  (330 . <Entity name: 1e75859a910>)
  (102 . "}")
  (100 . "AcDbDictionary")
  (280 . 1)
  (281 . 1)
  (3 . "AFSTROMING")
  (360 . <Entity name: 1e75859aa50>)
  (3 . "BEMALINGSGEBIED")
  (360 . <Entity name: 1e75859ab00>)
  (3 . "BOB_B")
  (360 . <Entity name: 1e75859aa70>)
  (3 . "BOB_E")
  (360 . <Entity name: 1e75859aa80>)
  (3 . "DIAMETER")
  (360 . <Entity name: 1e75859ab30>)
  (3 . "FE")
  (360 . <Entity name: 1e75859ab60>)
  (3 . "FUNDERINGSTYPE")
  (360 . <Entity name: 1e75859a9b0>)
  (3 . "GLOBALID_BEGINKNOOP")
  (360 . <Entity name: 1e75859ab80>)
  (3 . "GLOBALID_EINDKNOOP")
  (360 . <Entity name: 1e75859ab90>)
  (3 . "GN_CREATED_DATE")
  (360 . <Entity name: 1e75859a950>)
  (3 . "GN_CREATED_USER")
  (360 . <Entity name: 1e75859a940>)
  (3 . "GN_LAST_EDITED_DATE")
  (360 . <Entity name: 1e75859a970>)
  (3 . "GN_LAST_EDITED_USER")
  (360 . <Entity name: 1e75859a960>)
  (3 . "INSPECTIE_DATUM")
  (360 . <Entity name: 1e75859aab0>)
  (3 . "JAAR_GELEGD")
  (360 . <Entity name: 1e75859aa90>)
  (3 . "JAAR_INWINNING_BOB_B")
  (360 . <Entity name: 1e75859aba0>)
  (3 . "JAAR_INWINNING_BOB_E")
  (360 . <Entity name: 1e75859abb0>)
  (3 . "JAAR_ONDERZOEK_GEPLAND")
  (360 . <Entity name: 1e75859aac0>)
  (3 . "KAARTBLAD_1000")
  (360 . <Entity name: 1e75859a9a0>)
  (3 . "LENGTE")
  (360 . <Entity name: 1e75859aaa0>)
  (3 . "LIGGING_TERREIN")
  (360 . <Entity name: 1e75859a9f0>)
  (3 . "MATERIAAL")
  (360 . <Entity name: 1e75859ab20>)
  (3 . "MATERIAAL_SPECIFICATIE")
  (360 . <Entity name: 1e75859aa00>)
  (3 . "OBJECTID")
  (360 . <Entity name: 1e75859a930>)
  (3 . "OBJECTNUMMER")
  (360 . <Entity name: 1e75859a990>)
  (3 . "OORSPRONG_AFMETING")
  (360 . <Entity name: 1e75859a9c0>)
  (3 . "OORSPRONG_BOB_B")
  (360 . <Entity name: 1e75859a9d0>)
  (3 . "OORSPRONG_BOB_E")
  (360 . <Entity name: 1e75859a9e0>)
  (3 . "PROCESSED_FLAG")
  (360 . <Entity name: 1e75859a980>)
  (3 . "REDEN_MAATREGEL")
  (360 . <Entity name: 1e75859aa10>)
  (3 . "REVISIE_TEKENING")
  (360 . <Entity name: 1e75859aaf0>)
  (3 . "Shape__Length")
  (360 . <Entity name: 1e75859abc0>)
  (3 . "SOORT")
  (360 . <Entity name: 1e75859ab40>)
  (3 . "STABILITEIT")
  (360 . <Entity name: 1e75859aa40>)
  (3 . "STATUS")
  (360 . <Entity name: 1e75859ab10>)
  (3 . "STELSEL_TYPE")
  (360 . <Entity name: 1e75859aad0>)
  (3 . "STROOMGEBIED")
  (360 . <Entity name: 1e75859aa20>)
  (3 . "TEKENING_DISTRICT")
  (360 . <Entity name: 1e75859aae0>)
  (3 . "TYPE")
  (360 . <Entity name: 1e75859ab50>)
  (3 . "VORM")
  (360 . <Entity name: 1e75859aa60>)
  (3 . "WATERDICHTHEID")
  (360 . <Entity name: 1e75859aa30>)
  (3 . "ZUIVERINGSKRING")
  (360 . <Entity name: 1e75859ab70>)
if i drill down this dictionary we get a XRECORD with the value and containing ACAD_REACTOR.
My question is as follows:
Draw a new line with layername "N-OI-RI-TRANSPORTRIOOL_LEIDING_NG_600-G" retrieve the information from this layername with following lisp function:
(defun c:add-new-line (/ $activeDoc $diameter $entGet $entSel $i
                                       $intermediate $layerName $layerTable
                                       $materiaalLabel $n $obj $objSelect $splitResult
                                       $stelsel
  (setvar 'Cmdecho 0)
  (setvar 'Regenmode 0)
  (vl-load-com)
  (setq $activeDoc (vla-get-activedocument
                     (vlax-get-acad-object)
  (setq $layerTable (vla-get-layers $activeDoc))
  (setq $objSelect (ssget))
  (setq $i 0
        $n (sslength $objSelect)
  (while (< $i $n)
    (setq $entSel (ssname $objSelect $i))
    (setq $entGet (entget $entSel)
          $i      (1+ $i)
    ; N-OI-RI-TRANSPORTRIOOL_LEIDING_NG_600-G
    (setq $layerName (cdr (assoc 8 $entGet)))
    (setq $intermediate (nth 3 (LM:stringToList $layerName "-")))
    (setq $splitResult (LM:stringToList $intermediate "_"))
    (setq $stelsel (nth 0 $splitResult))
    (setq $leidingLabelName (nth 1 $splitResult))
    (setq $materiaalLabel (nth 2 $splitResult))
    (setq $diameter (nth 3 $splitResult))
    (if (= $diameter nil)
      (setq $diameter "0")
  (vla-put-activelayer $activeDoc (vla-item $layerTable 0))
  (setvar 'Cmdecho 1)
  (setvar 'Regenmode 1)
  (princ (strcat $stelsel ", " $leidingLabelName ", " $materiaalLabel ", " $diameter))
This function prints "TRANSPORTRIOOL, LEIDING, NG, 600"
from each value i want to create a xrecord(this i can do) and add(this i cant do) the information to the existing ESRI_attributes dictionary. I tried to get the hang of ACAD_REACTORS but can't figure it out how to realise this.
Hope somebody here can give me good advice which direction to go.
1483869724_TESTAWREACTORDATA.dwg
Edited by Revnixcad
Check out afralisp has some good tutorials about xdata and adding to an existing dictionary.
Together with my colleague @Semx11 we figured it out. Based on the code from the pdf mentioned above "Writing a Feature Class to the Named Object Dictionary" on page 3.
But instead of writing it to feature class we write the information to an object entity.
We added (vla-GetExtensionDictionary and it worked.
See code below.
(defun c:gisAddAttributesToEntity (/ $featureAttributes $objFeatures $objFeatureClass
                                   $objDict $objFeatureAttributes $fieldnameInt
                                   $fieldnameLong $fieldnameReal $fieldnameText
                                   $objResB $objList $objXrecd $objFieldInt
                                   $objFieldLong $objFieldReal $objFieldText
  (vl-load-com)
  ; ECHO COMMAND TO SCREEN
  (prompt "ADD ATTRIBUTES TO ENTITY")
  ; SET OBJECT NAME FOR THE ATTRIBUTE DICTIONARY
  (setq $featureAttributes "ESRI_Attributes")
  ; SELECT ENTITY
  (setq $entity (car (entsel)))
  ; GET OR ADD EXTENSION DICTIONARY
  (setq $vlaDict (vla-GetExtensionDictionary (vlax-ename->vla-object $entity)))
  (setq $extensionDict (vlax-vla-object->ename $vlaDict))
  ; CHECK IF EXTENSION DICTIONARY EXISTS
  (if (/= $extensionDict nil)
      ; FIND/ADD THE ATTRIBUTES DICTIONARY
      (if (= (dictsearch $extensionDict $featureAttributes) nil)
        ; CREATE A NEW DICTIONARY IF NOT FOUND
          ; CREATE A DICTIONARY ENTRY LIST
          (setq $objList (list '(0 . "DICTIONARY") '(100 . "AcDbDictionary")))
          ; CREATE A DICTIONARY OBJECT FOR ATTRIBUTES
          (setq $objDict (entmakex $objList))
          ; ADD THE ATTRIBUTES DICTIONARY TO THE EXTENSION DICTIONARY
          (setq $objFeatureAttributes (dictadd $extensionDict
                                               $featureAttributes
                                               $objDict
        ) ;_ progn
        ; ELSE GET THE EXISTING ATTRIBUTES DICTIONARY
        (setq $objFeatureAttributes (handent
                                      (cdr
                                        (assoc 5
                                                           $featureAttributes
      ) ;_ FIND/ADD THE ATTRIBUTES DICTIONARY
      ; SET ATTRIBUTE FIELD NAMES
      (setq $fieldnameLong "DIAMETER")
      ; SET ATTRIBUTE VALUES
      (setq $fieldDefaultLong 600)
      ; CREATE/ADD A FIELD DEFINITION FOR LONG INTEGER
      (if (= (dictsearch $objFeatureAttributes $fieldnameLong) nil)
          ; CONSTRUCT THE DATA LIST
          (setq $objResB (cons 90 $fieldDefaultLong)) ; change to 1, 40, 70, 90 depending on data type
          ; CREATE THE XRECORD LIST
          (setq $objList (append
                           (list '(0 . "Xrecord") '(100 . "AcDbXrecord"))
                           (list $objResB)
          ; MAKE THE XRECORD OBJECT
          (setq $objXrecd (entmakex $objList))
          ; ADD THE XRECORD OBJECT TO THE ATTRIBUTES DICTIONARY
          (setq $objFieldInt (dictadd $objFeatureAttributes
                                      $fieldnameLong
                                      $objXrecd
          ; INFORM USER
          (prompt
            (strcat "\n Fieldname = "
                    $fieldnameLong
                    "\n Data type = Long Integer" ; change this too
                    "\n Default value = "
                    (itoa $fieldDefaultLong)
        ) ;_ progn
        (prompt (strcat "\n Fieldname " $fieldnameLong " already exists"))
      ) ;_ if CREATE/ADD A FIELD DEFINITION FOR LONG INTEGER
      ; ELSE INFORM USER EXTENSION DICTIONARY NOT FOUND
        (princ "No extension dictionary found\n")
    ) ;_ if CHECK IF EXTENSION DICTIONARY EXISTS
  ) ;_ defun main function
