Creating a selection set from a list of objects inside a foreach funsction
The list of objects that I copy from a existing list needs to put into a selection set that I can manipulate them in an optimization program. I have tied to do this inside a foreach function but I keep failing at the syntax.   Example   (foreach pt (last optlist)(command "copy" pt "" baspt  despt)
        ; now create the selection set and number it for later placement
  The optlist can contain anywhere from 2 to 5 objects, in the selection set I need to optimize their placement with another placement, rotate, move.This is all done automatically in another lisp routine.
   I will try later to copy a cad drawing to this site for a better understanding .
  Allan
I have just added a stsample .dwg to my post. Here you can see how I optimize my tread placement. The new selection set I hope will allow me to place drill patterns on the optimized
plates.
Allan
stsample.dwg
In this case we need to know how optlist is generated and/or what its made up of. I myself prefer to use the foreach function.
If its a selection set.
(foreach ent (mapcar 'cadr (ssnamex SS)) ;used with ssget "_X"
  ;code here
(foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex SS))) ;all other ssget's
  ;code here
with lists its even simpler.
(foreach pt optlist
For this to work optlist would have to be entity names in that list
(<Entity name: 3820ff80> <Entity name: 3820e640> <Entity name: 3820e180> <Entity name: 3820dd80> <Entity name: 3820dec0>)
