Is there a way for the boundary command to not get nested island objects
I've posted a question on the non AutoLISP section about this problem but I was wondering if there was a way to fix this with a LISP routine.
I don't really know if this would be possible to fix the existing boundary command to fix this and think it would entail starting one from scratch.
What I would like is to only create the boundary for the 2 outer objects (i.e to only create a boundary of anything where the picked point is picked)
Here's the problem.
See the gif of what's happening. I'm using 2020.
If I use the boundary command or the hatch command and retain boundaries it gets the inner square as one too. Both exhibit the same problem.
I'll post the drawing file for people to test also.
Boundary Problem.dwg
Edited by 3dwannab
34 minutes ago, mhupp said:
Uncheck island detection.
Tried that but that only gets a boundary of the outer square. I was looking to get the 2 outer ones (where the pick was inside them two and not the inner square)
You are calling it a problem, but that is how the command works. Take a look at the first prompt it asks you to pick an 'internal' point from there the boundary finds the external boundary from that single point and also it finds ALL internal islands not just the first one it comes across. What you want to achieve is find the outer and only the closest inner boundary for that you would indeed need to uncheck island detection then use the boundary command twice, once internal to the outer perimeter and the second pick INTERNAL to that first island.
Thanks for explanation.
I was hoping there was a way around it via a LISP routine to only get the boundaries it hits on the inside of where it was and not any subsequent inner ones.
Their is always a way around things. It just depends on what you want. Do you always want to get the largest two shapes? You could then run thought the selection set sort by area. then just delete anything after the 2nd area.
Prob just simpler to pick what you want.
Edited by mhupp
I might try create boundaries with islands enabled and then ask the user for the boundaries to keep, then hatch them. I can't see no other way to get around it.
It's got to do with my hatch pick routine below. I run the command pick an existing hatch and pick inside a boundary.
Trouble with it is if I'm hatching a front elevation façade that has window frames inside the outer jamb, those window frames get a boundary around them.
Here's the lisp. Currently it uses addselected but I was planning on modifying it to use the boundary command and hatch those to try get around my issue.
(defun c:Hatch_In ( /
  *error*
  acDoc
  ent1
  ent1_data
  ent1_vla
  sel_me
  ss1
  ssHide
  tmp
  var_cmdecho
  var_hpannotative
  var_hpassoc
  var_hpbackgroundcolor
  var_hpbound
  var_hpboundretain
  var_hpseparate
  var_osmode
  var_selectioncycling
  var_snapmode
(defun *error* (errmsg)
  (and acDoc (vla-EndUndoMark acDoc))
  (and errmsg
   (not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*"))
   (princ (strcat "\n<< Error: " errmsg " >>\n"))
  ;;; Unhides the selection set
  (if ssHide (acet-ss-visible ssHide 0))
  (setvar 'cmdecho var_cmdecho)
  (setvar 'hpannotative var_hpannotative)
  (setvar 'hpassoc var_hpassoc)
  (setvar 'hpbackgroundcolor var_hpbackgroundcolor)
  (setvar 'hpbound var_hpbound)
  (setvar 'hpboundretain var_hpboundretain)
  (setvar 'hpseparate var_hpseparate)
  (setvar 'osmode var_osmode)
  (setvar 'selectioncycling var_selectioncycling)
  (setvar 'snapmode var_snapmode)
(setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc))
(setq var_cmdecho (getvar "cmdecho"))
(setq var_hpannotative (getvar "hpannotative"))
(setq var_hpassoc (getvar "hpassoc"))
(setq var_hpbackgroundcolor (getvar "hpbackgroundcolor"))
(setq var_hpbound (getvar "hpbound"))
(setq var_hpboundretain  (getvar "hpboundretain"))
(setq var_hpseparate (getvar "hpseparate"))
(setq var_osmode (getvar "osmode"))
(setq var_selectioncycling (getvar "selectioncycling"))
(setq var_snapmode (getvar "snapmode"))
(setvar 'cmdecho 0)
(setvar 'hpbackgroundcolor ".")
(setvar 'hpseparate 1) ; Separates the hatches to each boundary.
(setvar 'osmode 0)
(setvar 'selectioncycling 1) ;; 0 = The display options are turned off, 1 = A badge displays when you hover over objects that overlap, 2 = Both a badge and the Selection dialog box displays.
(setvar 'snapmode 0) ; gridsnap: 0 off, 1 = 0n
;; Put any text, leaders, multileaders or dimensions into a selection set and
;; hides them. The error handler will undo this.
(setq ssHide (ssget "_X" '((0 . "*TEXT,LEADER,MULTILEADER,DIMENSION"))))
(acet-ss-visible ssHide 1) ; Hides ssHide
;; TO DO:
;; Set the boundary to a layer
;; Try to fix the island issue when picking a facade where there is jambs. The window frames get a boundary line around them.
(while
 (not
  (and
   (setq
    ent1 (car (entsel "\nPlease select a HATCH to copy.\n: ------------------------------\n\nThen pick your point/s to Hatch_In'd."))
    ent1_data (if ent1 (entget ent1))
   (= (cdr (assoc 0 ent1_data)) "HATCH")
   (sssetfirst nil)
   (setq ent1_vla (vlax-ename->vla-object ent1))
     (setq ent_last (entlast)
       sel_me (ssadd)
     (while (setq tmp (entnext ent_last)) (setq ent_last tmp))
     (prompt "\nNow pick your hatch point !")
     (if (IsAnno-p (vlax-ename->vla-object ent1))
       (setvar 'hpannotative 1)
     (setvar 'hpassoc 1)
     (setvar 'hpboundretain 1) ; Retain boundaries
     (setvar 'hpbound 1) ; Create polyline boundary
     (setvar 'osmode 0)
     (if ent1
         (command "_.addselected" ent1 pause "")
         (while (< (getvar 'cmdactive) 0) (command ""))
         (command "_.draworder" (entlast) "" "_B")
     )(princ)
(*error* nil) (princ)
) ;; end Hatch_In
;; ----------------------=={ Functions START }==--------------------------
(defun IsAnno-p ( ent / exd ano )
  (vl-load-com)
  (and (eq (vla-get-HasExtensionDictionary ent) :vlax-true)
   (setq exd (vla-GetExtensionDictionary ent)
     exd (vla-item exd "AcDbContextDataManager")
     ano (vla-item exd "ACDB_ANNOTATIONSCALES")
   (not (zerop (vla-get-Count ano)))
  • 3dwannab changed the title to Is there a way for the boundary command to not get nested island objects
Just a random thought have you looked at closestpointto comparing your pick point and the plines made erase all other than 2 closest. The other without your sample dwg may be compare area of plines outermost should be biggest next maybe the other to keep. Sort ((area entity)
I was thinking doing something similar by perhaps pick once for the boundary and ask the user how many islands they want which could be 3 for example if I had 3 windows. Then delete every poly line after the 4th longest one (this would include  the external boundary, of course) and hatch the four remaining. Seems a sort of fool proof way (I think) 🤔
I get the sample portion of the drawing tomorrow as it's at work.
Edited by 3dwannab
I think the following could be easily made into a VLISP program.
  1. Change to layer 1
  2. Region command on all geometry
  3. Freeze layer 0.
  4. Union command on all but outer region.
  5. Subtract results from step 4 from outer shape.
  6. Hatch resulting region.
  • 1 year later...
