Byron md Posted February 13, 2009 Posted February 13, 2009 Are non uniform rational B - splines (nurbs) the same as sketch splines? Quote
shift1313 Posted February 13, 2009 Posted February 13, 2009 Not as far as i know. The nurbs is a generalization of a bezier curve. On a nurbs line or surface you have weighted control points(not on the curve). I believe what you are drawing is a B-spline. In solidworks when drawing a spline there should be two options in the dialog box. best fit(control points) or the other which i cant remember the terms used. The best fit curve should be a nurbs line. someone please correct me if im way off base Quote
Guest Sjano Posted February 15, 2009 Posted February 15, 2009 if you zoom into the sketch object and it is a true curve yes, if it it segments of lines no there can be oncurve and weighted points Quote
