Greetings,
I am looking for a Lisp routine to count number of objects within a block, and put the result inside of an existing text like a field. I found in Autodesk forum the next lisp routine that count the entities and their respective entity type, but from all blocks of the drawing at the same time, and I need to count each block, one by one plus the result linked to a text field (just the quantity as a number, nothing else. I am not interested in the entity type of the elements).
Somebody could help me with this, please... thanks a lot.
(defun c:cnt(/ blo doc js lst n tbl)
  (vl-load-com)
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (vlax-for blo (vla-get-blocks doc)
    (or (wcmatch (vla-get-name blo) "`**,*|*")
    (eq (vla-get-isxref blo) :vlax-true)
    (setq lst nil)
    (vlax-for ent blo
      (setq tbl (cons (vla-get-objectname ent) tbl))
     (while tbl
      (setq n   (length tbl)
        js  (car tbl)
        tbl (vl-remove js tbl)
        lst (cons (cons (itoa (- n (length tbl))) js) lst)
    (princ (strcat "\nWe have in the block : " (vla-get-name blo)))
    (foreach n (vl-sort lst '(lambda (a b) (< (cdr a) (cdr b))))
      (princ (strcat "\n"
             (substr "     " 1 (- 5 (strlen (car n))))
             (car n)
             (substr (cdr n) 5)
Edited by SLW210
Add Code Tags
Try this:
(defun c:cnt (/ r)
  (vlax-for b (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))
    (if	(= 0 (vlax-get b 'isxref) (vlax-get b 'islayout))
      (setq r (cons (cons (vla-get-name b) (vla-get-count b)) r))
  (mapcar 'print (vl-sort r '(lambda (a b) (< (car a) (car b)))))
(vl-load-com)
