I have the task of updating 1000+ CAD files with the wrong image name attached.
Each file has a corresponding image attached with this naming convention "A1234-X-01-1000.tif"
I have to change the attachment prefix from A1234 to A5678 but keep the rest of the image name.
               Old attachment name:  A1234-X-01-1000.tif -> New attachment name: A5678-X-01-1000.tif
The new images and drawings are saved in the same folder, and the path type is set to none in all CAD files.
I think Lee’s code below does a big part of what I need, but I know renaming the reference is not the same as renaming the attachment.
Does this work, or do I have to copy the image settings and reinsert the new image with the old settings?
I am just learning on how to reference and use the main dictionary.
Thank you for any of your recommendations,
(defun c:renameallimages ( / dic img itm lst )
   (if (setq lst (dictsearch (namedobjdict) "acad_image_dict")
             dic (cdr (assoc -1 lst))
       (while (setq lst (member (assoc 3 lst) lst))
           (setq itm (cdr (assoc 3 lst))
                 img (vl-filename-base (cdr (assoc 1 (entget (cdr (assoc 350 lst))))))
                 lst (cdr lst)
           (if (not (or (= img itm) (dictsearch dic img)))
               (dictrename dic itm img)
cadtutor.net - Changing Reference Names for Images - Lee Code
ExampleFile.dwg
Is there only one image with the same name for all the files ?
@densan
Try this mod of Lee's code ... test it!
(defun c:renameallimages (/ a b dic ext i img itm lst new)
	    img	(vl-filename-base (setq b (cdr (assoc 1 (setq a (entget (cdr (assoc 350 lst))))))))
	    ext	(vl-filename-extension b)
	    lst	(cdr lst)
      ;; Only add new prefix if a dash is in the name
      (if (setq i (vl-string-search "-" img))
	(progn (setq new (strcat "A5678" (substr img (1+ i))))
	       (if (not (or (= new itm) (dictsearch dic new)))
		 (dictrename dic itm new)
	       (entmod (append a (list (cons 1 (strcat new ext)))))
Edited by ronjonp
Thank you for the reply ronjonp; the code is perfect.
And to answer your question, each file has one image with a different name, but all follow the same naming convention.
    Filename01 has image A1234-X-01-1000.tif
    Filename02 has image A1234-X-01-1001.tif
    Filename03 has image A1234-X-01-1002.tif
Again thank you very much for the help. I will be studying the code to get better at this coding thing. Thank you,
Glad to help out. 🍻
