I having been using the following where i usually just place it in the command line then replace the values to what i need.
I am having a hard time trying to get this to a routine which would either ask me, at the command line rather than placing it within the ssx method.
(setq ss (ssget "x" (list (cons 2 "YourBlockNameHere")))) ;;will create a selection set of insertions for a given block.
(setq  ss (ssget "_X" (list (cons 0 "*TEXT")(cons 1  "*TEXTVALUE*")))) ;;select text with wildcard value
Thanks for any direction.
Like this?
;; Select Text with Wildcard
(defun c:stw ( / wildcard ss)
;; comment out one of those possibilities
  ;; in case the user needs to write the * symbols
  (setq  ss (ssget "_X" (list (cons 0 "*TEXT")(cons 1  (setq wildcard (getstring "\nWildcard (include * where needed):" T)) )))) ;;select text with wildcard value
  ;; in case the there's always *...*
  (setq  ss (ssget "_X" (list (cons 0 "*TEXT")(cons 1  (setq wildcard (strcat "*" (getstring "\nWildcard (don't include *):" T) "*")) )))) ;;select text with wildcard value
;; just to see that it works, print the number of selected *text objects
  (princ (sslength ss))
(setq ss (ssget "_X" (list (cons 2 (cond (getstring "\nYour block name wcmatch pattern : ") ("*"))))))
(setq ss (ssget "_X" (list (cons 0 "*TEXT") (cons 1 (cond (getstring T "\nSpecify value wcmatch pattern of *TEXT entity types for ssget search : ") ("*"))))))
Edited by marko_ribar
Thanks you guys! I think I can make this work.
