As a learning exercise, I am trying to write a routine that will create an mtext entity and list all the types of external references missing in the current drawing.
I attached a sample file for reference.
The scope is to create an mtext object that evaluates current missing xrefs and returns the following:
    Missing external reference: dgnExternalreference-01.dgn
    Missing external reference: dwfExternalreference-01.dwfx
    Missing external reference: dwgExternalreference-01.dwg
    Missing external reference: excelFile-01.xlsx
    Missing external reference: imgExternalreference-01.jpg
    Missing external reference: pdfExternalreference-01.pdf
My approach is this
  1. Get the object names for each xref type
  2. Determined if they are missing somehow
  3. Create a list for each xref class
  4. Create mtext object
  5. Fill in mtext with list values
I would appreciate it if this forum could please give me some feedback on what I'm doing wrong and what concepts, functions, or references I need to study.
I'm struggling with what method to use to get the dwg xref information (ssget, dictionary or vla) and many more things as a noob. The following code is the only part I feel is somewhat correct.
Thank you,
;;; Text creation reference https://www.cadtutor.net/forum/topic/17870-entmake-and-mtext/
;;; Xref from dictionary reference https://www.cadtutor.net/forum/topic/74541-renaming-attached-images/
(defun c:txtmissxref ( / dlxref dgnxrf dwfxrf imgxrf pdfxrf)
;get a count of datalinks
(setq dlxref (cdr (assoc -1 (dictsearch (namedobjdict) "acad_datalink"))))
;get a count of dgns
(setq dgnxrf (cdr (assoc -1 (dictsearch (namedobjdict) "acad_dgndefinitions"))))
;get a count of dwfs
(setq dwfxrf (cdr (assoc -1 (dictsearch (namedobjdict) "acad_dwfdefinitions"))))
;get a count of images
(setq imgxrf (cdr (assoc -1 (dictsearch (namedobjdict) "acad_image_dict"))))
;get a count of pdfs
(setq pdfxrf (cdr (assoc -1 (dictsearch (namedobjdict) "acad_pdfdefinitions"))))
;mtext creation
 (setq txtloc (getpoint "\nSelect insertion point"))
 (setq txtvals "Hello World")
 (entmakex (list
	    (cons 0 "MTEXT")
	    (cons 100 "AcDbEntity")
	    (cons 100 "AcDbMText")
	    (cons 10 txtloc)
	    (cons 1 txtvals)
addtxtMissingxref.dwg
Since your trying to learn ill only give you bits of what should work.
What you have gets the entity name of the dictionary group.
((-1 . <Entity name: 27cab6e0>) (0 . "DICTIONARY") (5 . "202A8") (102 . "{ACAD_REACTORS") (330 . <Entity name: 27cab6a0>) (102 . "}") (330 . <Entity name: 27cab6a0>) (100 . "AcDbDictionary") (281 . 1) (3 . "fraction-to-decimal-table") (350 . <Entity name: 27cb09a0>))
what you want is the all the 350's in that group not the -1
(setq imgxrf (dictsearch (namedobjdict) "acad_image_dict"))
(setq imgxrf (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 350)) imgxrf)))
This will make a list of entity names of all images in the drawing.
Step through each entity and use findfile.
(foreach img imgxrf
  (setq path (cdr (assoc 1 (entget img)))) ;gets path to image
  (if (eq (findfile path) nil) ;if you don't find file aka missing or moved.
    ;create list to write to mtext
Edited by mhupp
Thank you mhupp ,
I will study your suggestions, and it's great to have a bit of direction.
I was going crazy trying to guess how to apply bits from other sources or articles.
If I could ask for help on another subject, what do I look for to understand the difference when I get results in these two different formats?
    I am using the watch window in the AutoCAD Visual LISP IDE, and sometimes..
    Data is returned in a single line list
    ((-1 . <Entity name: 27cab6e0>) (0 . "DICTIONARY") (5 . "202A8") (102 . "{ACAD_REACTORS").......
    And sometimes data is returned in a vertical list
    [0] (-1 . <Entity name: 27cab6e0>)
    [1] (0 . "DICTIONARY")
    [2] (5 . "17")
    [3] (102 . "{ACAD_REACTORS").......
Thank very much for the help.
Because  either the function its self or the lisp is using a loop to display information. Like these two functions that I Use to collect data of like objects when coding.
the vlax-dump-object must have a loop in it and the mapcar 'print is the loop.
;; Dump all methods and properties for Visual Lisp Objects
(defun C:VDumpIt (/ ent)
  (if (setq SS (ssget))
    (foreach ent (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
      (vlax-Dump-Object (vlax-Ename->Vla-Object ent) t)
      (textscr)
;; Dump all DXF Group Data
(defun C:DumpIt (/ e)
      (mapcar 'print (entget ent '( "*")))
      (textscr)
Haven't used AutoCAD since late 2015. And really only picked up lisp after my switch to BricsCAD so I can't really cant compare the two.
In Briscad it Allows you to see how its getting information in a variable *last-value* this is what is shown when stepping though just this line of code.
-1
<Entity name: 3fae0350>
((-1 . <Entity name: 39b6920>) (0 . "DICTIONARY") (5 . "81") (102 . "{ACAD_REACTORS") (330 . <Entity name: 3fae0350>) (102 . "}") (330 . <Entity name: 3fae0350>) (100 . "AcDbDictionary") (281 . 1) (3 . "Capture") (350 . <Entity name: 39b66a0>))
By inspecting the third line I had 4 images attached to the drawing. that line had  4 (3 . "Capture") (350 . <Entity name: 39b66a0>) each 3 had the name of the image file.
That's how I knew to cut down
to
(setq dwfxrf (dictsearch (namedobjdict) "acad_dwfdefinitions"))
Then process it thought vl-remove-if-not to get all the entity names
Hopefully AutoCAD acts something like that and just doesn't process the whole line in one go and spit out <Entity name: 39b6920>
