Siberian Posted February 13, 2009 Posted February 13, 2009 I'm having some trouble with a vieport together with the Wipeout command. Wipeout has been used on an area. I then plan to have a viewport on top of it that covers part of this area. Problem is that only the viewport's borderline is shown, and the actual contents of the viewport is hidden by the Wipeout command. I've tried to fool around with the Draw order commands but they only affect the viewports borderline. Any ideas? Quote
JBullseye74 Posted March 9, 2009 Posted March 9, 2009 Mate all i can suggest is a block something like this one maybe.......... i've knocked it up very quickly to give you an idea. any use to you ? WIPEOUT BLOCK.dwg Quote
Organic Posted March 9, 2009 Posted March 9, 2009 I had this exact same problem last Friday. Did not find a solution and ended up making a hashed together fix with a polygonial viewport. Quote
