Lisp routine(s) to control section plane position/thickness and type (plane/slice)
Hi,
I'm using section planes (SPLANE) to slice up point-clouds.
The more keyboard based commands the better.
To create a section plane I might select the cloud then type -
SPLANE enter O enter T enter
This will create a section plane orthographic to the WCS looking top down on the cloud. (I'm using LayDirectorV1-9.lsp to force the section plane into layer A-section-plane regardless of what my current layer is).
If I then want to move the section plane up or down or swap to a slice of a certain thickness, I have to do various mouse clicks and dragging or clicking in the ribbon.
I'd like to be able to perform these secondary adjustments using keyboard/lisp commands.
I have at the moment  the aforementioned SPLANE and a system variable SECTIONSPINNERS that displays the dialog box to set the increment value for the Section Object Offset and Slice Thickness controls in the Section Plane ribbon contextual tab. The section plane is an object with xyz geometry and other properties, examples below -
EXAMPLE PLANE -
Command: LIST
Select objects: 1 found
Select objects:
                  SECTIONOBJECT  Layer: "A-section-plane"
                            Space: Model space
                   Handle = 1000057c
Name: Section Plane (1)
Type: Plane
Insertion:  X=   20.731,  Y=  720.556,  Z=   26.648
Rotation: 42.064513
Normal:  X=    0.000,  Y=    0.000,  Z=   -1.000
Top Plane:    16.825
Bottom Plane:    16.825
Point at:  X=   20.731,  Y=  720.556,  Z=   26.648
Point at:  X=   42.726,  Y=  740.405,  Z=   26.648
EXAMPLE SLICE -
Command: LIST
Select objects:
                            Space: Model space
                   Handle = 1000057c
Type: Slice
Rotation: 42.064513
Top Plane:    16.825
Angle A: 0.000000
Angle B: 0.000000
Point at:  X=   42.726,  Y=  740.405,  Z=   25.491
Point at:  X=   20.731,  Y=  720.556,  Z=   25.491
My goal is to be able to create a section plane and then control it's position from the keyboard with maybe a lisp routine that can move the section plane or or down by increments by repeatedly pressing a key/s, and similar control of slice thickness. But I don't know how to go about extracting this information and manipulating it within Lisp.
Any help/knowledge appreciated.
Thanks
Quentin.
