The AutoCAD Blog Posted March 29, 2022 Posted March 29, 2022 New AutoCAD 2023 features are here to further automate processes and collaboration. Whether you need to add feedback to your drawings, see insights to learn about process improvements, or utilize the LISP API from the web, AutoCAD 2023 delivers. AutoCAD 2023 was designed with our customers and the changing nature of their work in mind. The new Markup Import and Markup Assist features help you automatically import feedback into your drawings, reducing the risk of errors and saving you time. Add written comments and feedback from Trace layers in just a couple of clicks of your mouse. With My Insights, you can learn about new features or workflows, curated specifically for you based on the way you uniquely use AutoCAD. With the power of Autodesk’s integrations, you can manage tasks like plotting with fewer hang ups and customization with more flexibility. The LISP API is now available in the AutoCAD web app. You can use it to customize your AutoCAD experience and automate repetitive processes wherever you are, on any computer. In addition, the cloud-first Sheet Set Manager in AutoCAD 2023 now enables you to open sheet sets faster from Autodesk Docs. Using the Autodesk cloud platform, sending and opening from Autodesk Docs sheet sets to and from teammates is quicker and safer. “We’re excited about the future of the AutoCAD and are committed to addressing our customers’ rapidly evolving modern workflows,” said Dania El Hassan, Director of AutoCAD Product Management. “With Markup Import and Markup Assist and My Insights: Macro Advisor in AutoCAD 2023, both powered by machine learning, we strive to make sure the time users spend in AutoCAD continues to be efficient and productive. The automations and insights we’re developing will continue to leverage the latest technology to guide users toward completely new design outcomes.” AutoCAD 2023 and the AutoCAD web and mobile apps give you the most comprehensive web and mobile capabilities of any CAD software. You have the flexibility to design, draft, edit, share, and markup drawings in AutoCAD from a desktop, web, or mobile device. With the AutoCAD web app, you can now upload drawing templates, plot styles, and other support files to create DWG files that better meet your company’s drafting standards. You can also take advantage of seven industry-specific toolsets in AutoCAD with thousands of parts, symbols, and diagrams to help you with electrical, mechanical, architecture, piping, plant designs, and more. For instance, with the Architecture toolset you can quickly place walls, doors, and windows into your drawings with real construction properties. The toolsets are updated for 2023 to help you connect to and retrieve data from the Autodesk platform, import and edit data from spreadsheets, quickly filter files to find projects, repeat projects, and much more to maximize productivity and shorten your project cycles. Save time implementing feedback with Markup Import and Markup Assist Markup Import and Markup Assist will help you rapidly send and incorporate feedback into your designs. With Markup Import, you can take feedback from the field on printed paper or a PDF and import them as a trace layer in AutoCAD. AutoCAD detects the markup and converts it to an object. Markup Assist then allows you to add the text or object to your drawing automatically with a click of a button. Markup Import and Markup Assist makes collaboration and revisions simple. Get curated tips to increase your productivity with the My Insights: Macro Advisor My Insights, the advisory engine that helps you work faster using machine learning algorithms to deliver you curated insights, now provides insights while you work in the form of recommended macros that automate your most frequently repeated workflows. In addition to the dashboard in the start tab where you can view a variety of personalized usage insights, macro insights will appear as a notification at the bottom of the screen as you are working. Clicking on these macro suggestions will take you to a new Command Macro Palette where you can learn more, save a suggested macro, and even tailor the macro to your needs. The My Insights: Macro Advisor is a frictionless guide to provide valuable information to you at the right time and in the right context. Customize and automate your workflows anywhere with the LISP API for AutoCAD web Whether you are on the go, at a job site, or anywhere you decide to work, create your own customizations to automate sequences of steps with LISP in the AutoCAD web app. Load or manage LISP files and type in LISP commands just as you would with AutoCAD on your desktop to save time and complete designs faster. This feature is only available to AutoCAD subscribers. Enhancements and improved performance AutoCAD 2023 also includes several enhanced features to improve the user experience. Many users wanted floating windows to have their own command lines. Now they have them! The command line is available in any active window. Trace is enhanced so you can create trace layers from AutoCAD desktop in addition to the web and mobile apps. In addition, you can now add to Traces that were created by others further enhancing your ability to collaborate. Safely add design change notes and markups to a drawing directly in AutoCAD without altering the existing drawing. Count is also enhanced to further automate counting objects, including within an area you select. The Count toolbar’s added functions allow you to select counted objects; use the arrow keys to move to the previous or next counted object; and directly insert a count field to a table or text. AutoCAD 2023 includes updated graphics for rendering 3D objects up to 10 times faster than before when using the shaded, shaded with edges, and wireframe visual styles. Get started today Get started today and explore the new features by logging into your Autodesk Account and downloading the latest release. If you are not yet a subscriber, check out free 30-day trials of AutoCAD 2023 and AutoCAD LT 2023. Join the webinar on April 21 to learn more about what’s new in AutoCAD 2023.Learn more about the AutoCAD web app and AutoCAD mobile app. AutoCAD 2023 for Mac and AutoCAD LT 2023 for Mac AutoCAD 2023 for Mac and AutoCAD LT 2023 for Mac are also now available, and you can read about the new features here. Explore more The post AutoCAD 2023 Unveiled: Experience Deeper Insights, Collaboration, and Automation appeared first on AutoCAD Blog. View the full article Quote
