Recorded Macro error
Sometimes when I try run a recorded macro I get a compile error: "user - defined type not defined" Highlighted is Dim: pw photworks as photoworks.photoworks.
go to your tools menu, add-ins and unselected photoworks. Photoworks is the render setup inside solidworks and for some reason or another it causes issues with the macros. ive run in to that as well. I think you can manually edit the macro but make sure you have this add-in turned off before you start recording and you should be fine.
